Car forgets to pop and crackle sometimes
I’ve noticed over the past few weeks that sometimes on the down shift in sport mode the car forgets to pop bang and crackle. For example yesterday on the way home from Gatwick which took me an hour all worked fine was banging popping down the lanes, but after around 45 mins no pop or banging, i changed the drive select to comfort then back to dynamic and this got it back. Has anyone else ever had this?
Re: Car forgets to pop and crackle sometimes
Yep mine does that too.johnny11 wrote: ↑Sun Oct 13, 2019 9:24 amI’ve noticed over the past few weeks that sometimes on the down shift in sport mode the car forgets to pop bang and crackle. For example yesterday on the way home from Gatwick which took me an hour all worked fine was banging popping down the lanes, but after around 45 mins no pop or banging, i changed the drive select to comfort then back to dynamic and this got it back. Has anyone else ever had this?
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- 1st Gear
Mine comes and goes every few minutes.. Audi said no fault
Glad its not just mine then.
- 1st Gear
Is it not cause the car goes into 4 cylinder mode then you don't get the exhaust noise. Usually does that when your cruising on a motorway
- 1st Gear
Did you switch off ignition at any point? I find I always have to cycle in and out of S/D mode after starting up. Seems to always default to off, even if your Drive Select mode should be in sport.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Previous:
S/D??
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Drive and Sport on the gearbox (pulling down gear leaver switches between the two). It will only pop and crackle in S mode.
Previous:
Previous:
Users browsing this forum: Google [Bot] and 65 guests
