Acceptable Parasitic Drain
Daytona
Post by Daytona » Wed Sep 18, 2019 8:14 pm
I’m getting 200mA, the Internet seems to suggest 50mA is the magic number.
What do you think?
mikep99
Re: Acceptable Parasitic Drain
Post by mikep99 » Wed Sep 18, 2019 8:25 pm
Seems quite high to me...
I was monitoring mine a while back and after 10 mins or so of the car being left alone (ie. locked or doors closed), the drain was about 60mA.
I assume you've been checking for a reason?
How have you checked the drain - multimeter at the battery?
ta
Mike
Robnic
Post by Robnic » Wed Sep 18, 2019 8:43 pm
Too high that's fifth of an amp, when presented at the garage with a job like this we generally look for under 80mA. Some newer stuff is slightly more but a B7 wants to be 60mA or less.
B7 RS4 MTM K540 Sprint loon, Lysholm/Opcon twin-screw supercharger, Ceramics, HEL Hoses, Loba SM Fly, Sachs performance clutch kit, MTM full stainless exhaust system with freeflow cats & quad valved tailpipes, Hotchkis ARB's, Bilstein B16 Coil Overs, LED Rear lights, Interior & LED 50W DRL's, Buckets in race cloth, Black optics, FBSW, Titanium pack, Solar Sunroof, Adaptive lights, MTM 10mm spacers Fr & Rr, 193 Nav unit, 2nd careful owner :-)
Daytona
Post by Daytona » Wed Sep 18, 2019 8:45 pm
I thought was high too.
I left it for half an hour to fully shut down but didn’t drop.
I’m checking it as it’s been getting progressively slower to turn over in the mornings, finally not starting yesterday, charged the battery and took it to be tested but as I thought, it’s fine (wants to be, only 2.5 years old)
I checked it at the battery, well made some cables up, shut the boot and connected the multimeter up outside.
Daytona
Post by Daytona » Wed Sep 18, 2019 8:47 pm
Oh, and disconnected the Bluetooth module under the drivers seat as I’d read that’s a favourite but made no difference.
Attempted pulling fuses but kept triggering the aftermarket alarm 🙄
Robnic
Post by Robnic » Wed Sep 18, 2019 9:01 pm
If you have it in the garage roll all your catches that way you can have all the doors boonet and boot open which makes things easier, there is a method of measuring milli-voltage across fuses which equates to current draw but it's a bit hit and miss.
We use an oscilloscope and amp clamp powered through the mains to avoid amp clamp battery voltage drift, oh and a thermal imaging camera over the last few years!
Can be a tricky job, good luck.
Daytona
Post by Daytona » Wed Sep 18, 2019 9:11 pm
I did roll the drivers door catch to trick the car into thinking it was shut but even with the OE alarm ultrasonics disabled via the button the aftermarket alarm microwave sensors were tripping.
Robnic
Post by Robnic » Wed Sep 18, 2019 9:15 pm
They shouldn't lock it with the blade, they can take over half hour to go to sleep fully.
Daytona
Post by Daytona » Wed Sep 18, 2019 9:23 pm
Blade as in key?
If so I meant I pushed the catch in on the door then locked the car with the door open via the button on the key. Are saying don’t lock it?
Robnic
Post by Robnic » Wed Sep 18, 2019 9:32 pm
Yes lock it with the key blade not the remote plip.
Daytona
Post by Daytona » Wed Sep 18, 2019 9:33 pm
Tomorrows job then 👍🏻
Daytona
Post by Daytona » Sun Sep 22, 2019 8:03 pm
Well, it was the add-on DAB radio, with that disconnected dropped to 60-90mA, (multimeter was fluctuating a lot).
Hopefully that’s low enough to not cause any issues.
Cheers all 👍🏻
mikep99
Post by mikep99 » Sun Sep 22, 2019 8:05 pm
Glad its sorted!
Which DAB add on do you have?
Does it not have auto shut down after x amount of time?
ta
Mike
Daytona
Post by Daytona » Sun Sep 22, 2019 8:15 pm
Cheers Mike,
Just an Alpine Ezi DAB, I tee’d (properly with an add in loom) off the cd changer feed for an ignition live via a relay and expected it to that but it was the unit itself, display went off as it should but just sat there draining the battery whilst “off”!
Robnic
Post by Robnic » Sun Sep 22, 2019 8:58 pm
Infotainment components in general are favourite more so if aftermarket, kudos on the result.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 137 guests
