Miltek rattle
Miltek rattle
I have a miltek cat back non resonated exhaust which has an annoying flutter/rattle sound when off the throttle at around 1500 revs.
I'm guessing it's something to to with the valves which are disconnected using the Miltek valve delete.
Has anyone else had this problem and found a solution?
MM
MM
2017 RS6 PE Nogaro
Re: Miltek rattle
I’ve been holding off posting exactly the same!
It sounds like a loose panel in the boot, but is definitely valve related.
I think I’ll get it checked out.
Re: Miltek rattle
I Reconnected my valves and it’s still noticeable
Re: Miltek rattle
A squirt of wd40 in the end of the exhaust normally gets rid of it for a while. Try that, if it works you can try a more permanent solution (ptfe spray etc maybe?)
Re: Miltek rattle
1. it can be the extra spring under the valve that is giving you issues (wd40 helps some time, removing the spring fixes it forever and lets you sleep good at night).
-> see other topic on here where i explained it better including pictures....
2. the milltek has an tinny H pipe that makes internal sounds way more audiate. I always guessed the dual flip wastegate port flapper kinda was the influencer and what you are hearing. Since i replaced the poor quality H with an X pipe the milltek sound more refined (but way softer).
Re: Miltek rattle
If it's like a ticking sound when off the throttle around 1500rpm, then had it on both my 6's - assumed it was part and parcel of the Milltek.
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Re: Miltek rattle
Agreed. Mine has been like this since I got the Miltek and always felt the noise didn’t warrant the work required to try remove the common rattles off throttle. WD40 never worked for me either.
Edinburgh Based Nardo Grey C7 RS6
- uplandsway
Re: Miltek rattle
Like Mr C7 RS6 Mike says do the WD40 trick before you scrap it for the new APR System
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
Re: Miltek rattle
Spray the valves regularly - did do with both of them, though not to get rid of ticking noise, more OCD of not wanting the valves to stick. Not sure it's a fault per se with the exhausts as it seems to occur on most of them / a large number of them - normal behaviour with exhaust? Has anyone spoken to Milltek to ask them directly?
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Re: Miltek rattle
I have sprayed the valves and it doesn’t seem to do much.
The valves are disconnected so shouldn’t be moving
2017 RS6 PE Nogaro
- uplandsway
Re: Miltek rattle
Have you tried the opposite wayMountainMutant wrote:I have sprayed the valves and it doesn’t seem to do much.
Plug valve units back in
Soak the internals in WD40 overnight
Use in comfort and sport to see if it frees up issues and continue to soak units
Or just eBay the milly and buy the APR, huge step forward in terms of quality and sound
Cheers,
Stevie F
Stevie F
Users browsing this forum: 0770chris23, Google [Bot] and 109 guests
