About 2000rpm when I press full throttle rattling noise coming from somewhere. Anyone had this issue before?
Is it can be a pressure plate or the DA flywheel? Or what else?
Rattling noise
Re: Rattling noise
Heat shields? They aluminum held on with steel nuts and rot through
Re: Rattling noise
I vaguely recall a TSB that came out regarding a rattling noise at low rpm and disappears once the rpm increases over roughly 3k. The solution was to re-shim the L/H output flange on the front diff.
Re: Rattling noise
Does it have a Forge oil cooler? The early ones made a noise around 1800-2000rpm as there was slight movement in the mount kit.
Misano Red RS4 B7 Avant
Re: Rattling noise
No I have the oem oil cooler.
About the front diff what you suggest to do?
My mechanic said the noise could be the flywheel.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 122 guests
