SEAT Exeo RNSE Sat Nav in B7 RS4...
fairzy
Re: SEAT Exeo RNSE Sat Nav in B7 RS4...
Post by fairzy » Mon Aug 19, 2019 7:17 pm
HPsauce wrote:Good luck sorting it out. Presumably the next stage is, after charging the battery again, leaving the Bose amp disconnected....
After charging the battery fully I checked the voltage and it read 12.58v. I then did some further testing with the BOSE amp and a multimeter. After about 10 minutes the reading drops to 0.004 whether the BOSE amp is plugged in or not, so I think I can rule that out. After about 30 mins of taking readings etc the battery has dropped to 12.5v.
I'm running a VCDS scan to see if anything comes up. I also checked the battery age and it seems to be the original battery but I don't want to replace it unnecessarily, especially if that's not the problem.
Anything else I should be checking or just replace the battery? Image
Sent from my Pixel 3 using Tapatalk
Jon_J
Post by Jon_J » Mon Aug 19, 2019 7:19 pm
If you have disconnected the amp. Remember you are only looking at the audio because you changed something. And the battery is still draining, stop looking at the audio. It’s a red herring.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
fairzy
Post by fairzy » Mon Aug 19, 2019 7:29 pm
You could be on to something. Tried to start it again and... Flat battery! Won't even turn over.
Post by MikeFish » Tue Aug 20, 2019 12:15 am
If the battery is 13 years old there is a very good chance it is toast. Personally I'd have changed the battery by now anyway, no-one wants to end up stranded with a car that won't start especially once the winter comes and it becomes harder to start the car.
Rick_RS4
Post by Rick_RS4 » Tue Aug 20, 2019 8:30 am
Change the battery , I had a few issues of battery drain but thought it was because I didnt drive it enough, then one day dead changed to a new one and now it's a good strong start no issues . Batterys only have a 10 year life max I'm sure I read on it
HPsauce
Post by HPsauce » Tue Aug 20, 2019 10:21 am
If it's the original battery, being a B7 is at least 10 years old, I'd change it anyway at the first hint of any problem. Which you've had...
It owes you nothing now and has lasted way longer than most. 8)
fairzy
Post by fairzy » Tue Aug 20, 2019 10:29 am
Just picked up a new Bosch S5 battery ready to be fitted later
Rick_RS4
Post by Rick_RS4 » Tue Aug 20, 2019 3:43 pm
Jon_J wrote:
Mon Aug 19, 2019 12:50 pm
Rick_RS4 wrote:
Jon_J wrote:
Sun Aug 18, 2019 8:43 am
The 7 digit post code is part of the disk. The screen quality is much better on the RNSE2 and still uses the DIS.
I use DAB through my phone connected via the AMI. Can also navigate music from the RNSE , artists, playlist etc.
Is there a specific AMI that you need, do you have a link ? I take it that it only works on the newer rnse
Will only work with RNSE MK2.
Thanks that's next on my list but unsure which one to go for at the minute
Kenny147
Post by Kenny147 » Wed Aug 21, 2019 3:37 am
The only AMI unit that’ll work with a Mk2 RNSE in a B7, is the A3 unit 8P0. Don’t be tempted to get the cheaper B8 A4 unit. No one that I know of has got one to work.
Rick_RS4
Post by Rick_RS4 » Sun Aug 25, 2019 1:11 am
That's great to know. Just need to find out what rnse to get
ChrissDeejay
Post by ChrissDeejay » Tue Sep 01, 2020 8:30 pm
Hi Jon,
Could you post the coding that you use on your Exeo RNS-E ?
I am interested due to the fact that I purchased an A3 AMI-CAN and my Exeo RNS-E does not accept the coding for AMI ... it give error31 : coding out of range.
I am on the latest RNS-E software, from the latest and final maps DVD.
Thank you in advance.
Br,
Cristian
Jon_J
Post by Jon_J » Tue Sep 01, 2020 8:39 pm
ChrissDeejay wrote:
Rick_RS4 wrote: Is there a specific AMI that you need, do you have a link ? I take it that it only works on the newer rnse
Hi Jon,
Br,
Cristian
Which part are you coding, show me what you have or are trying to do.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
ChrissDeejay
Post by ChrissDeejay » Thu Sep 03, 2020 5:10 pm
I am trying to code the AMI option into RNS-E.
RNS-E P/N : 3R0 035 192 (Exeo Unit with MEDIA button, LED screen and so on ... )
Current coding : 0310155
Needed coding : 0330165
AMI P/N : 8P0 035 785
According to ross-tech website (http://wiki.ross-tech.com/wiki/index.ph ... acteristic), in my case, I should increase the bit 0xxxx?x with 1 digit, resulting in 0330165. But when I do that, the VCDS returns error31, out of range coding.
Not even 0330125 works, which has only AMI coded.
Any suggestions are welcomed.
Thank you.
Jon_J
Post by Jon_J » Thu Sep 03, 2020 7:47 pm
ChrissDeejay wrote:I am trying to code the AMI option into RNS-E.
Thank you.
Ok I will have a look.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Jon_J
Post by Jon_J » Fri Sep 11, 2020 7:39 pm
Thank you.
Second from last digit should be a 2.
Try that tell me what happens
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Users browsing this forum: No registered users and 307 guests
