Brake pads
Brake pads
Am I right in saying the OEM For the brake pads are made by ATE for the Front and PAGID For the rear?
Also just Looking at a post from a while ago did anyone get these front brembo pads from the seller and if so were they ok?
https://rover.ebay.com/rover/0/0/0?mpre ... 2795496150
- uplandsway
Re: Brake pads
Hijohnny11 wrote:Am I right in saying the OEM For the brake pads are made by ATE for the Front and PAGID For the rear?
Think it’s Brembo front and Rear tbh, but you can get OE equivalent ie ATE and so on..
Brembo Rears are avail from Eurocarparts and Brembo Fronts from EBay and Amazon (same prt nos as Merc and so on)
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
Re: Brake pads
I've had EBC YellowStuff pads on all round for the last 35k miles with the OEM discs. With racing brake fluid (not sure what type) I noticed a massive difference in braking performance which was very disappointing at first.
Re: Brake pads
Ive ordered the front Brembo’s from here which include the wear sensors, all in for a tad under £70
https://www.autodoc.co.uk/brembo/11804327
I believe they are the same ones ECP are selling for £214.
So will see if they are any good.
- uplandsway
Re: Brake pads
Just checked and ECP now sell both front and rear Brembo, there’s usually discount deals on too so worth checking as today front and rear brembos are £191 giving a saving of over £100johnny11 wrote:Ive ordered the front Brembo’s from here which include the wear sensors, all in for a tad under £70
https://www.eurocarparts.com/brake-pads
Cheers,
Stevie F
Stevie F
Re: Brake pads
If you use code MID60 It brings it down to £151uplandsway wrote: ↑Sat Aug 10, 2019 10:13 pmJust checked and ECP now sell both front and rear Brembo, there’s usually discount deals on too so worth checking as today front and rear brembos are £191 giving a saving of over £100johnny11 wrote:Ive ordered the front Brembo’s from here which include the wear sensors, all in for a tad under £70
Re: Brake pads
Asked to new pads in and was told they can't as the disc is worn in so they would to machine the disc and since its drilled, they don't want to machine it which means I need to get new pads and discs wtf
2017 BMW M2
2015 Nardo Grey RS6 Facelift
- uplandsway
Re: Brake pads
If you want OEM Crewe Audi Parts on here will sort you out mateykoruki wrote:Asked to new pads in and was told they can't as the disc is worn in so they would to machine the disc and since its drilled, they don't want to machine it which means I need to get new pads and discs wtf
Cheers,
Stevie F
Stevie F
Re: Brake pads
Careful getting pads from ECP. In the past they have sold the cheaper compounds from certain manufacturers and they're dangerous.uplandsway wrote: ↑Sat Aug 10, 2019 10:13 pmJust checked and ECP now sell both front and rear Brembo, there’s usually discount deals on too so worth checking as today front and rear brembos are £191 giving a saving of over £100johnny11 wrote:Ive ordered the front Brembo’s from here which include the wear sensors, all in for a tad under £70
Re: Brake pads
After all that I went OEM for discs and pads all round as the car is under warranty for another year, but sourced the discs myself from Cardiff Audi front and I think MK Audi for the rear and got my local indie to fit my discs but they supplied and fitted the OEM pads. Saved me around £1k but still using OEM parts.
Users browsing this forum: Google Adsense [Bot] and 107 guests
