Front suspension banging
Joew85
Post by Joew85 » Wed Jun 19, 2019 10:12 pm
Hi I hope someone can help.i have a 2004 rs6 .it has coilovers fitted but over medium and large bumps it makes a harsh loud bang on both front corners as if the shocks are bottoming out.the front coilover shocks have been changed but no difference.i have check all arms and bolts I can see but I cant see anything obviously wrong.has anyone had anything similar.thanks in advance
Ben_r1
Re: Front suspension banging
Post by Ben_r1 » Thu Jun 20, 2019 1:02 am
Check to see if the steering rack is insecure or the bolt are loose
Post by chunky79 » Thu Jun 20, 2019 6:15 am
Check the top suspension mounts.
Also, check your brake pedal for play.
Post by Shoppinit » Thu Jun 20, 2019 6:21 am
Avoid bumps.
benh999
Post by benh999 » Thu Jun 20, 2019 12:26 pm
What’s the issue with brake pedal play?
Post by chunky79 » Thu Jun 20, 2019 2:00 pm
It rattles and feels like you have a problem with the suspension.
Joew85
Post by Joew85 » Thu Jun 20, 2019 2:45 pm
Ah this is a solid harsh bang.teally feels like its bottoming out
benh999
Post by benh999 » Thu Jun 20, 2019 4:56 pm
That’s strange, I get that rattle/vibration on the driver side however I’m sure it feels like it’s the acccelerator that rattles?
Post by chunky79 » Thu Jun 20, 2019 5:02 pm
Grab your brake pedal and give it a tug, think you'll find there's a little play in it
Did you replace your top mounts when you changed the coilovers?
Joew85
Post by Joew85 » Thu Jun 20, 2019 6:14 pm
I didnt originally fit the coilovers but when I changed on the other day I didnt.they looked in good condition and were a tight fit into the upper carrier
ahoooga
Post by ahoooga » Thu Jun 20, 2019 7:21 pm
Did you check all bushes as well ?
Joew85
Post by Joew85 » Thu Jun 20, 2019 7:31 pm
Yeah checked it all over no play has had new upper arms and carrier on the near side too
Daveperc
Post by Daveperc » Thu Jun 20, 2019 9:07 pm
Have you checked the springs? I broke one on the rear on one of these??
Dave
Covkiller
Post by Covkiller » Thu Jun 20, 2019 9:09 pm
At least some fcukers banging :drink:
