Brake Caliper removal
PaulT
Post by PaulT » Thu May 23, 2019 8:55 am
Needing to remove front brake calipers for refurb to sort out corrosion lifting the plates and change discs. Has anyone tried removing the caliper but undoing the 2 radial allen bolts (10mm) that mount the caliper to the hub mounting bracket. The allen bolts are more accessible than the big 21mm bolts on the rear fixing the bracket to the hub upright so thinking easier to get undone. Done some googling but can't find any mention on forum or web.
Thanks for any insight.
Daytona RS4
James1984
Re: Brake Caliper removal
Post by James1984 » Thu May 23, 2019 9:09 am
No problem doing that at all, only thing I found was that my 10mm Allen keys were slightly loose in that the bolts stuck to them and had to be backed off
PaulT
Post by PaulT » Thu May 23, 2019 8:25 pm
Great, thanks for feedback James
Daytona RS4
Users browsing this forum: MK1_LOVE and 185 guests
