Engine and heat dissipation
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Post by c3nturi0n » Wed May 22, 2019 11:54 am
hey guys,
with summer coming i'm sure you all have similar challenges re the amount of heat that V10's produce :).
I was wondering is there anything that could be done to address this challenge on C6's (especially when using a car for long motorway journeys)? e.g. not an issue per se, but more of a concern that the amount of heat that remains under the bonnet is / could be harmful for rubber/plastic components longer term.
Interested to hear your thoughts/suggestions?
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Re: Engine and heat dissipation
Post by Jim Haseltine » Wed May 22, 2019 1:12 pm
During a journey it's not a problem, it's afterwards - Audis have always retained heat (my 1980s Coupe GT would still be hot hours after I'd parked it). All you can really do is plan journeys so that the last few miles are done with little load on the engine (it helps to turbos no end as does following a turbo cool down procedure) and if possible lift the bonnet for a while when you park. Not that it'll have any real effect unless you did it every time you drove the car and maybe not even then.
Mine is 2008 with over 110K on it and (I suspect) wasn't treated too well prior to my ownership but the only pieces that seem to have suffered under the bonnet are the ribbed plastic breather pipes. And the turbos of course, now I've got it apart the RH turbo is coked up the worst of any I've had in 20 years of driving turbo cars.
c3nturi0n
Post by c3nturi0n » Wed May 22, 2019 5:25 pm
thx Jim. I'd echo on your thoughts.
I was thinking should they've done more to dissipate the heat - e.g. fin type openings on the bonnet, heat / air out ducts on the wings etc. Aesthetics aside, it would have helped longer term.
- H&R ARBs
IanH755
Post by IanH755 » Wed May 22, 2019 7:56 pm
While it would be an aesthetic nightmare, a vented bonnet is 100% the best option with one vent either side above each manifold (for the car once it;s parked) and a low pressure vent at the front & above the front of the engine (for when it;s driving), at bit like this god-awful CF A4 one from China. However, while I think that even a painted version would look awful, others are entitled to their own opinion on vented bonnets (had one on my R34 etc).
or these C6 bonnets with vents added -
c3nturi0n
Post by c3nturi0n » Wed May 22, 2019 10:14 pm
Cheers Ian... that’s more in line of my thoughts.
I guess side / wing opening is a no go?
- H&R ARBs
Toady1
Post by Toady1 » Thu May 23, 2019 7:47 am
Got any pics of this???
c3nturi0n
Post by c3nturi0n » Thu May 23, 2019 10:27 am
I'd be keen to see it too :).
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Thu May 23, 2019 11:48 am
I think the only piece I haven't cleaned completely yet is the heat shield and that's been soaking in solvent for a day or so. As the carbon was several mm thick in places there's probably a fair bit left so I'll see if I can post a pic later.
Doug_RS6
Post by Doug_RS6 » Thu May 23, 2019 2:28 pm
I thought about having louvres stamped into the original bonnet. Perhaps inverted so they went down rather than sticking up.
c3nturi0n
Post by c3nturi0n » Thu Jun 20, 2019 5:03 pm
That'd be cool...
- H&R ARBs
Doug_RS6
Post by Doug_RS6 » Mon Jul 08, 2019 8:24 pm
Would look fairly subtle.
IanH755
Post by IanH755 » Tue Jul 09, 2019 7:28 pm
While it might be great for cooling the negative is that it would let water drain onto the hot engine, turbos and electrics whenever it rains unless you cover it when parked. I had an R34 with a vented bonnet and had to replace the vicous fan, air con rad and silicone seal the back of several plugs after nearly 2 months of water related issues.
Jim Haseltine
Post by Jim Haseltine » Tue Jul 09, 2019 10:22 pm
And the servo hose. To be more specific, the two plastic pipes of the Y shaped inlet/vacuum pump/servo assembly #4 here. Which might explain why my brakes seem to have no servo assistance first thing in the morning.
cammmy
Post by cammmy » Tue Jun 09, 2020 10:42 am
Is the RS6 bonnet the same as the C6 A6? If so, I'm thinking about picking one up and experimenting. Don't fancy hacking up my only bonnet.
On the Cooper S, I added vents near the top mount in the hopes of helping flow through it. I haven't measured IAT but anecdotally, the rad fan doesn't kick on nearly as much when idling/at low speed.
welwynnick
Post by welwynnick » Tue Jun 09, 2020 12:57 pm
According to SSP431 all the side panels were changed on the RS6, but not the bonnet, so I suppose that means it's the same as the A6.
