Modern Head Units - Kenwood, Pioneer, etc.
Hi,
How much functionality do you lose if you fit one of these in an RS7 ? I don't mind losing SATNAV and CD Changer, but it sounds like I'll lose the ECU connection for car settings etc ? Are any head units more integrated than others ?
Ta
Ian
Ta
Ian
Ian
B7 RS4 Avant
1984 911 Carrera (hotrod)
B7 RS4 Avant
Re: Modern Head Units - Kenwood, Pioneer, etc.
What do you mean by car settings? I don't recall any car setting on my RNS-E on my RS4 Avant?
You lose the sat nav comms to the central display between the tacho and Speedo in every aftermarket unit that I'm aware of. Some units (Alpine) can retain the song / track info to this display, others you'll lose this too.
That's it I believe.
Yep, what Alex and James said. No car settings on the RNSE.
Thanks ! What do the "Car" and "Setup" buttons do then ? I must confess I couldn't see that they did anything useful, but just assumed they did !
Ian
B7 RS4 Avant
B7 RS4 Avant
So...I've spoken to a few car audio places (some of them *much* dodgier than expected) and it seems like quite an involved job to fit a new head unit with DAB and handsfree. My car already has the bluetooth handsfree though - is there a way to use the existing microphone or do they really have to fit a new one ?
Ian
B7 RS4 Avant
B7 RS4 Avant
- 1st Gear
It’s really not. The most tricky bit is wiring in a switched live as the OEM unit uses CANBUS to tell it to switch on or off. But anyone semi competent in wiring can do that. The rest is plug and play.
DAB involves a self adhesive aerial to the inside of the windscreen - I’ve done away with normal FM now as it’s so much better.
Hands free is simply putting a mic in the rooflining. It’s all just running wires behind trim.
Agreed. Not that hard, pretty basic. For me the big pain in the install was filtering noise from the speaker lines.
Kenwood DMX7017DABS seems to be well respected, so I'll probably go with that unless there's a better recommendation ? I might even have a go at fitting it...what could possibly go wrong...
Is there a particular ISO adapter kit you used for the rns-e replacement ? There seem to be quite a few that fit the car.
Ta
Ian
Ta
Ian
Ian
B7 RS4 Avant
B7 RS4 Avant
Have a look through my build thread about fitting, should give you a bit of an idea. I’m still waiting for my ground control loop to arrive so I can fit that and a canbus interface to sort the illumination too.
- 1st Gear
That’s the unit I have. It’s very good - does everything I need and is easy to navigate. I had some issues with ground feedback but they were mostly caused by an unamplified FM adaptor. Like I said, now I have DAB, I don’t use FM anyway so just disconnected it. Still get a tiny bit of noise but just haven’t got round to fitting ground loop isolators yet.monkeychap wrote: ↑Sun Apr 21, 2019 8:12 pmThanks
Ta
Ian
Background noise tend to come from the RCA outputs which you can buy suppressors that work online or buy a high and low adapter to run off the speaker leads to run RCA's
I run one of the new android units which I love.
Do you have a link to the isolators your talking about? I just bought a unit and will be fitting it once the facia plate arrives. Thanks John
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
I just got this one for my bose rca harness,
https://rover.ebay.com/rover/0/0/0?mpre ... 3092233355
Cheers for that take it it's just wires from car into it then into the head unit?FrazerD wrote: ↑Thu Apr 25, 2019 3:25 pmI just got this one for my bose rca harness,
Cheers![]()
