I'll take it this is just coded through Vagcom then?Kenny147 wrote: ↑Wed Apr 03, 2019 11:32 amWhether it’s simply an urban myth that’s grown a life of its own or whether it’s based on reality, too many owners have had the flickering light issue and changed the bulbs, only to have to change the ballasts not that long after.
I know I did.
It might cost you more in the short term but as some of these cars are now over 12 years old, it makes sense to just change the bulbs and ballasts at the same time. Especially as it’s a bumper off job and the bumper is such a joy to remove.![]()
My only piece of advice is that you have to code the new ballast to the car before you can adapt it. It’s not difficult to do but you can’t simply plug it in and have it work without errors.
Headlight ballasts
Re: Headlight ballasts
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
Does these look like the right ballasts?
If you go the brand new route, they should already be coded for the B7, if they’re second hand or refurbed units that came from an A3, for example, you’ll have to code them to the car. You then adapt the units. It’s not difficult and you can do it all through Vagcom/VCDS. There’s a thread on Audizine that explained it all. I’ll have a look and post the link for you.
Have a look at the part number on the Sticker, on the top of your headlights. You only need one side and then you can be sure to get the right ballast. Or you can run a Vagcom scan and it’ll list the individual ballast part numbers in the results.
Let me know what the headlight part number is and I’ll get you a ballast part number. PM me if you want.
Thanks for all your help I'll get a look in the morning and pm you the detailsKenny147 wrote: ↑Thu Apr 04, 2019 10:29 pmIf you go the brand new route, they should already be coded for the B7, if they’re second hand or refurbed units that came from an A3, for example, you’ll have to code them to the car. You then adapt the units. It’s not difficult and you can do it all through Vagcom/VCDS. There’s a thread on Audizine that explained it all. I’ll have a look and post the link for you.
You will need these callibrating at Audi.
I have one ballast somewere laying.. oem peice!
Send me an dm on Instagram @softishman
@softishman on IG
Check out my RS4 there!
I will do thanks is it for adaptive headlights?Softishman wrote: ↑Sun May 12, 2019 8:26 pmI have one ballast somewere laying.. oem peice!
The ballast is the same for all xenon, with or without AFS.
@softishman on IG
Excellent that helps a lot.Softishman wrote: ↑Wed May 15, 2019 1:18 pmThe ballast is the same for all xenon, with or without AFS.
Users browsing this forum: Google Adsense [Bot] and 162 guests
