Is it 100% necessary to use the electric handbrake whilst parked? My dad insists it doesn’t matter if you don’t use it, but I’m worried about the health of his gearbox long-term. I’ve kept trying to tell him to use it but he won’t listen.
The C7 has the electronic hand brake incorporated into the main rear caliper.wildbore wrote: ↑Tue Apr 02, 2019 7:06 amYour father should google "automatic gearbox parking pawl" and see the small plate and the weak spring that the auto box uses to implement the gearbox "P-Park" function. It is simply a slim metal plate with a small hook on it held in place by a lightweight spring. Then imagine leaving that to hold 2 tonnes of car stationary on a steep hill. And then compare all that to a full handbrake mechanism with shoes and drums on each rear axle (what is the handbrake setup on the RS6? Is it a separate drum, or incorporated into the rear calipers?).
You would have to be mad - or an American citizen - not to use the handbrake whenever the car is stationary.
Thanks for that, now that I have a solid reason he might listen to me.wildbore wrote: ↑Tue Apr 02, 2019 7:06 amYour father should google "automatic gearbox parking pawl" and see the small plate and the weak spring that the auto box uses to implement the gearbox "P-Park" function. It is simply a slim metal plate with a small hook on it held in place by a lightweight spring. Then imagine leaving that to hold 2 tonnes of car stationary on a steep hill. And then compare all that to a full handbrake mechanism with shoes and drums on each rear axle (what is the handbrake setup on the RS6? Is it a separate drum, or incorporated into the rear calipers?).
It's a fair point - but they also put signs on the sides of roads that are steep telling you to park with your wheels pointing hard into the kerb (curb) so that the kerb will stop you when your car rolls off. You don't see that in the UK.
Because of rust?MikeFish wrote: ↑Tue Apr 02, 2019 10:48 amThe C7 has the electronic hand brake incorporated into the main rear caliper.wildbore wrote: ↑Tue Apr 02, 2019 7:06 amYour father should google "automatic gearbox parking pawl" and see the small plate and the weak spring that the auto box uses to implement the gearbox "P-Park" function. It is simply a slim metal plate with a small hook on it held in place by a lightweight spring. Then imagine leaving that to hold 2 tonnes of car stationary on a steep hill. And then compare all that to a full handbrake mechanism with shoes and drums on each rear axle (what is the handbrake setup on the RS6? Is it a separate drum, or incorporated into the rear calipers?).
The only time I don't use the handbrake is after washing the car and parking it back in my level garage.
Yes, otherwise they rust together and make a loud noise when trying to drive off.Tadass910 wrote: ↑Tue Apr 09, 2019 10:39 amBecause of rust?MikeFish wrote: ↑Tue Apr 02, 2019 10:48 amThe C7 has the electronic hand brake incorporated into the main rear caliper.wildbore wrote: ↑Tue Apr 02, 2019 7:06 amYour father should google "automatic gearbox parking pawl" and see the small plate and the weak spring that the auto box uses to implement the gearbox "P-Park" function. It is simply a slim metal plate with a small hook on it held in place by a lightweight spring. Then imagine leaving that to hold 2 tonnes of car stationary on a steep hill. And then compare all that to a full handbrake mechanism with shoes and drums on each rear axle (what is the handbrake setup on the RS6? Is it a separate drum, or incorporated into the rear calipers?).
