Miltek Race exhaust flaps
Re: Miltek Race exhaust flaps
Euhm, you always use your audi/OEM electric actuators (the 'motor' you bolt onto the flap mechanisme so that isn't the issue. Maybe the coil spring between the actuator and flap gets softer over time but didn't had luck finding them as seperate part. Just dump that little milltek spring
. You do not want to drive the car hard with closed flaps for long time....
If you want an akra type of sound, just replace your milltek H into an X pipe
My Miltek is non resonated version does it make sense? Where that X pipe can be purshased?dasquade wrote: ↑Wed Mar 20, 2019 7:08 pmIf you want an akra type of sound, just replace your milltek H into an X pipe. Did it on mine and lost indeed that typical milltek raspy deep sound into a more turbo blown refinder sound.
For time being I am very happy with Miltek sound (2 years)
Rs6 or s6? Rs non res has no silencers up front, s6 non res has silencers. Sadely i couldnt find 70mm/2.75" x pipe so had to made a converted 3" x pipe.
