Rear Diff bearings
5.0 V10 50v biturbo - 571 bhp
floatdrop
Rear Diff bearings
Post by floatdrop » Sun Feb 03, 2019 11:51 pm
Hi All,
I had a slight whine in the diff between 80-70KPH on decel. The diff was removed and disassembled by my transmission guy. He found one of the carrier bearings had lost its hard face off the tapered roller bearings. He and i have found replacement bearings impossible to purchase. Audi claim that the diff is not serviceable and must be replaced with new?
Can anyone assist with bearing numbers, or where i can purchase them or a service kit?
Andrew
ATinOf
Re: Rear Diff bearings
Post by ATinOf » Thu Feb 07, 2019 10:30 pm
Long shot but these guys might be able to help, they offer rs4 diff components, you may get lucky...
https://www.ebay.com/itm/AUDI-OEM-96-08 ... SwqLpa2H8j
Jim Haseltine
Post by Jim Haseltine » Fri Feb 08, 2019 10:34 am
IME, most bearings have a code on them - often it's etched into one of the non-bearing faces. Just to make things awkward, it's usually a mounting face so you can't see the code until you've removed the bearing.
floatdrop
Post by floatdrop » Mon Mar 04, 2019 2:48 am
To close out this thread.
The diff carrier,tapered roller bearings are made by SKF in Brazil. The numbers on the shell and cone cannot be sourced through SKF or cross referenced to another brand.
I ended up finding a low KM diff and installing it.
Another good reason to replace the diff oil regularly.
Doug_RS6
Post by Doug_RS6 » Mon Mar 04, 2019 6:52 am
Surely the bearings could be measured and sized for an appropriate replacement? If someone makes the bearing I find it most unlikely that they made them only for Audi direct.
floatdrop
Post by floatdrop » Mon Mar 04, 2019 9:42 am
