Yikes!!MikeBirt wrote: ↑Wed Feb 27, 2019 10:55 amThis looks familiar...
My P zero is exactly the same, rest of tyre has good wear, edges are coming apart. I have a set of PSS waiting for me this week.
I have had PSS on my B8 RS4 and the turn in and balance on that car was amazing. The 6 is an understeer disaster (all geo's checked and re-checked). I'm hoping that the the PSS will re-coup some lost ground as I'm no fan of these PZ. Audi tells me they are OEM recommended for my car :-/
https://imgur.com/a/WuU90vW
I will check the pressures though - as wear on the edge and not on in the middle sounds like under pressure to me.
Just as a side note - on full lock do your front wheels 'hop''?
as if the suspension kinematics are all wrong for the wheels... (geo oem stock check 3x now.)
From my experience I've seen this only on cars with oversized wheels.
Yeah, all of the permanent quattros grumble on full lock on tarmac.
Several threads on C7 geo - one several pages long headed up by Mikefish I think. If you have tried three times with factory Audi geo and wish to reduce the understeer, one option to consider is to wind the rear axle toe-in back to zero. Virtually all cars come with nice safe boring understeer inducing rear toe in - the C7 certainly does stock from factory. Winding this back to zero will make the car much more pointy. Even going from 0.2 or 0.25 degrees back to 0 each side makes a big difference.
*Mike, please insert link below!
