Ideal tyre pressure
mister_g
Ideal tyre pressure
Post by mister_g » Wed Feb 27, 2019 10:11 am
I've been running mine at 32psi front and rear which feels good but the orange tyre pressure light is constantly on
What is the lowest pressure I can get away with that won't trigger the orange light?
I thought there was something wrong with it as 32 is ok in my book, but the garage set them to 39 front and 36 rear which is way too harsh a ride IMO
With my black B7
I'm in B7th heaven
And with DRC
My ride is heavenly
:blackrs4:
MIDZ
Re: Ideal tyre pressure
Post by MIDZ » Wed Feb 27, 2019 12:28 pm
I'm sure the spec is 38psi front & 35psi rear for 255/35/19's. The chart is in the drivers door sill, not sure what the lowest setting is right enough?
I would've thought if you run tyre pressures lower than manufacturer spec you'd get uneven tyre wear?
FrazerD
Post by FrazerD » Wed Feb 27, 2019 12:54 pm
I run 36 all round and don’t get warnings.
Cheers :thumbs:
simonardern
Post by simonardern » Thu Feb 28, 2019 12:01 am
I run mine At 36 psi all round as well, very even tyre wear and have dcc so cant say they affect the ride.
demon8991
Post by demon8991 » Thu Feb 28, 2019 5:52 am
^^^THIS^^^
R8 V10 Gen 1 • Phantom Black • Coupe • Gated Manual • Quicksilver Valveless Exhaust • REP RamAir Filters • CF Interior/Engine/Side Blades • Wireless Apple CarPlay
RS4 B7 • Phantom Black • Centre Resonator Delete • Wireless Apple CarPlay
SQ5 TDI • Ibis White • Fully Optioned • Wireless Apple CarPlay
Brooner
Post by Brooner » Thu Feb 28, 2019 8:24 am
I use the manufacturer's recommendations on all of my previous RS4's and don't believe i got uneven wear certainly don't get uneven wear in my currant B8 and i have had that for 6 years
But i do rotate the tryes when changing from summers to winters
simonardern
Post by simonardern » Thu Feb 28, 2019 8:33 am
Ignore my post, I have a golf r, but follow the rs4 forums as well (it’s the dream) posted in wrong section, my bad.
12th
Post by 12th » Thu Feb 28, 2019 8:41 am
I run standard with a PSI or so dropped off the fronts.
QuRace
Post by QuRace » Thu Feb 28, 2019 9:28 pm
You can get away with a lot, b/c, IIRC, you can modify the warning thresholds of the TPMS, e.g. using VCDS, or the in-car setup.
Ignoring the manufacturer's recommendations towards lower pressure is, I would claim, at your own peril though.
rocket1
Post by rocket1 » Sat Mar 02, 2019 8:33 am
You can set the pressures your happy with them store them in the menu and then you won't get the warnings coming on.
repsol honda fireblade.
JamesBaby
Post by JamesBaby » Sun Mar 24, 2019 12:10 am
Wear is almost irrelevant. Note that too low a pressure is a major cause of blow outs. The tyres compress and flex too much in use and get too hot and burst. People incorrectly think too high a pressure is the problem.
Tyre pressure is not just some arbitrary thing one should choose. It’s set by the oem for a reason and they even go to the lengths of setting it according to load level of the car.
The Sticker on the car is what one should follow. There’s even an 18 inch spec if you want more comfort and willing to change wheel size for it.
Seattle-squash
Post by Seattle-squash » Tue Mar 26, 2019 5:08 pm
I run 40psi front/back with 275/30/19, and good wear.
Users browsing this forum: Zyox and 442 guests
