4 Wheel alighment
4 Wheel alighment
anyone had this done and can share their settings?? still seems to be a lot of squidgy rear and torque steer issues in here. I am sure with the right setup they can both be illuminated or reduced to acceptable levels.
I will get mine done soon and share my results. no rear end issue with my car ( although RS7 it might help RS6 as well) but suffer from torque steer now its mapped. If I can collate some info from others before I get mine done I can figure out the best settings and trial them.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Re: 4 Wheel alighment
I can post my RS6 results later. I had it done after lowering 40mm then had it done again when I changed to adjustable springs and lifted it a bit.
That would be great
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
I could only find the original one that I had done after lowering 40mm. From memory, when I went back after raising it, they made very little changes.
that's great thanks.
interesting re the front geometry. Did you feel the difference on steering response pre and post? pre steering should have felt quick and a bit unsteady when cruising compared to post, steering should feel slower but less inputs to keep straight?
depending on my current setup (prob a good chunk of toe out) I intend going toe- in on the front to increase straight line stability and reduce torque steer.
I know you don't have torque steer, not sure if that's due to your suspension or the fact you are still stock? prob the better suspension?
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
I've had mine done twice recently in the las 10 months. Both on hunter machines. 1st time was general mot station 2nd time I used My engineer who works on my GT4s as car did not feel right at the back. A lot better now. Will try and get print outs later when Im back home
Sorry, I read this on the train originally and forgot to respond.Paulm wrote: ↑Fri Feb 08, 2019 12:35 pmthat's great thanks.
There was a huge difference (for the better) in steering and how the car turned. The car felt smaller and lighter than before. The car was only a few weeks old at the time so not sure if it was just the alignment or the combination of lowering and alignment.
Here's my recent check for comparison
Car was much more balanced and agile, with substantially less wandering under power and across camber changes as a result.
Due another check in the next few weeks.
Looks like this thread is gaining traction
Dave, did you forget to attach your pic? Maybe I just can’t see it as I am on phone only at the moment?
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Sorry forgot to "share" on Google - should be there now!
Just had mine done at revolution Gateshead after new tyres can’t recomend Glenn and the lads enough although I stay in central Scotland these guys have done bits n pieces on my cars for years and very professional evert time no complaints ! They’re genuine enthusiasts and re aligned my milltek to stop it hitting transmission tunnel was not installed by them
sorry for late reply, just back off hols. No still cant see it
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
I could see it before but now I can only see the no entry sign.
- uplandsway
That’s my most recent if it helps
Was on 21” PE wheels with Dunlop winter tyres and KW HAS
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
How is your front camber correct with it lowered?uplandsway wrote: ↑Mon Feb 25, 2019 6:53 pmThat’s my most recent if it helps
Users browsing this forum: Daveperc and 110 guests
