Drain holes had blocked in the binnacle there, so it had filled with water and the main 150a fuse cable had rotted away completely. A simple enough fix in the end...
Did you post this issue on the forum before pulling your car apart? I don't spin a spanner much at all but even I would put the main fuses under the scuttle forward as the culprits.adowds wrote: ↑Mon Feb 25, 2019 10:46 amJust a headsup for anyone with similar problem - took me a while to find it. Had total electrical failure a fortnight ago - nothing, like the battery was disconnected. Took most of the interior apart, suspected CCM module etc, before finally finding the two big main 150 and 200 amp fuses on the firewall below the windscreen. They're totally hidden by the coolant expansion tank aren't they? Gah. I only found them when I saw the green corrosion dust that had flaked off lol.
Luckily, no, all good, E-box and interior all dry. My drive has a bit of a slope, and the car was parked sideways so maybe that has saved me. You can see on the pic how high the water was, just lapping at the lower fuse.
