Does DRC leak on the floor?
Picking up my RS4 next week, anyone got a guide on checking the DRC? Will leaks be obvious or do I need to get underneath the car to check the shocks and the steel pipes?
Re: Does DRC leak on the floor?
In my case when it went was all over the rear diff and exhaust and floor
Just had mine go on the O/S front shock. No oil on the floor, just under gator of shock and running 5 PSI.
Cheers fellas, if system sealed what should the pressure read if I ask them to test it? Car from main dealer so they should have the equipment
- innercry666
20 PSI.
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
23 PSI I was told. Guess around that mark is reasonable.
You are all wrong.
It’s Bar, not PSI 18-22 is the range.
Cheers guys
20 bar is quite a lot pressure, hope nothing fails catastrophic
Users browsing this forum: Sadie110 and 39 guests
