Can't find this part
Re: Can't find this part
I had these codes along with a few others when my fan was running at all times. I replaced the coolant temp sensor and all of them went away. Might be something to look at after you diagnose your module and fan to be in good working order.
Thanks all for the comments and suggestions. As a matter of facts I've changed the coolant temperature sensor last week, part of a preventive maintenance campaign along with the N249 valve and a few other bits. But no change on the faut codes, as expected in my case..
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
^Joke for the initiated. If you look back far enough you'll get it.
Ha, at least I didn't jump on it saying it must be a great upgrade
You should definitely get the R8 coolant cap though.
Yeah, just started saving for that one!
You figure out where your problem is? Did you do the output tests with the Vagcom?
Unfortunately no, didn't find a minute to do the tests yet. Hopefully this should be done over the weekend, and I'll report of course. Thanks again for the follow up.
Right, so I did the output tests and both fans can be activated fine using the Vagcom. I suppose it simply means my second-hand fan ECU is also faulty? Shout...
With the engine stone cold, if you clear the fault codes then run the fan with the Vagcom does the fault code appear immediately?
If not, then do the same test when the car has just been driven and everything is hot.
If it faults only when hot, then could be a bad solder joint on the PCB. Or possibly water ingress damage.
Or it could be bad wiring / electrical connections. Most likely at or near the connector. How do the contacts look?
If you tap the unit when it's running the fan with a screwdriver or something, does it fault out?
You could always open the old module and try reflowing everything if you've got the gear and the know-how. I fixed a friend's S8 ECU this way (that was water ingress damage). No-one was more surprised than me.
Hi Shopp,
With the engine cold, I can indeed clear the codes and they come back only when the car has been driven. Looks like it doesn't take long for the codes to come back but I'll try to investigate what triggers them as suggested above. Good suggestions also regarding the option to repair the old ECU, I'll give it a try: may be an faulty transistor or voltage regulator, which I could manage. Never dared to try that, but with a bit of luck it may be something obvious. Many thanks again, I'll keep you guys posted of course.
Would you mind adding the steps followed in VCDS to perform the output tests? Might be good for someone who stumbles across this thread in the future.
2004 Audi RS6 Avant Plus #283
Sure MeTsu, actually it's quite straightforward and well documented on the VCDS Rosstech website (Google "VCDS output tests").
Select the engine ECU, click on the output test button.
Then just start the output tests sequence. Activation of the secondary and primary fans is one of them. Don't wait too long, the fans won't spin forever. If you're lucky enough your VCDS version can allow direct access to each specific test (not my case).
Does that help?
Best
Does that help?
Best
Thanks Classik, all good, just thought if someone popped into the thread and didn't know.Classik wrote: ↑Tue Feb 12, 2019 7:05 amSure MeTsu, actually it's quite straightforward and well documented on the VCDS Rosstech website (Google "VCDS output tests").
Does that help?
Best
