That time of year again... Failed for the 2nd year Iv'e had it !
Mark-RS
Post by Mark-RS » Wed Jan 30, 2019 1:09 pm
But not as substantial as the last time :D
M.O.T day gives me the following...
Headlight level is low.
Rear pads, which I knew were getting low anyway.
And Emmisions ! Which has suprised me !
Only failed on the Lambda readings, which judging by the paperwork should be between 0.97 and 1.03. Mine reads 1.16
They didn't really have a clue what the issue was but said, maybe exhaust leak, which they didn't find on inspection, air leak or sensor issue ?
Mark-RS
Re: That time of year again... Failed for the 2nd year Iv'e had it !
Post by Mark-RS » Thu Jan 31, 2019 11:34 am
So any advice on things I can get the garage to look at for this Lambda reading ?
simonpoulton
Post by simonpoulton » Thu Jan 31, 2019 12:18 pm
Check your OE exhaust (if you still have it) around the welds on the resonators. Mine had cracked and was giving high lamda readings. Replaced with Milltek naturally...
Past: R56 Mini Cooper S
Ajc
Post by Ajc » Thu Jan 31, 2019 12:22 pm
Could also be a cat on it's way out . Did he check the reading on both tips or just the one ?
Cheers Al
Mark-RS
Post by Mark-RS » Thu Jan 31, 2019 1:21 pm
Only checked on one tip. Passenger side.
Left it running at about 4krpm for about 10 mins which I though a bit much...
Daveperc
Post by Daveperc » Thu Jan 31, 2019 2:54 pm
The hotter the better to get low readings.
R56WUF
Post by R56WUF » Thu Jan 31, 2019 3:27 pm
My previous RS6 failed on the emissions test at Dundee Audi. I went and drove the car for about 1/2 mile with the car in second gear at approximately 60mph, took it straight back and the tester hooked it up and it passed. Always worth giving the system a wee blast.
2004 C5 RS6 - Missano Red (the fastest colour...) - Departed
2004 C5 RS6 - Sprint Blue (the prettiest colour...) - Poorly
Mark-RS
Post by Mark-RS » Thu Jan 31, 2019 7:07 pm
I did take it for a run before going there, but due to it being -2 I couldn't really give it any stick :-(
I really hope it's not the Cat... Don't see why it would be ? They don't go very often do they ?
I'm hopeful a service and a good check for leaks in the system should cure things :-)
PipRS6
Post by PipRS6 » Fri Feb 01, 2019 9:44 am
Yup, cats don't work unless they're warm. That's the point of the pre-cats. Closer to the engine they warm up quicker. Give it a good thrashing then ask the tested to do emissions first.
Post by Shoppinit » Fri Feb 01, 2019 10:14 am
What do the car's lambda probes read? If they are not complaining and the car is failing emissions then it seems likely that one or both have failed.
Ajc
Post by Ajc » Fri Feb 01, 2019 11:07 am
Lambda reads air fuel mixture , they had a certain amount of tolerance , however I think the car uses a mixture of lambda and egt top work out how it needs too tweek it's running. In the turning world egt a bit more too . On the car the pre and post lambda is checks and altered , though I think the pre is more for the sia side and pre heating the first cat . I service and fresh filters can go a way too changing lambda reading though , so may be worth trying it if you've not already
Cheers Al
Ben_r1
Post by Ben_r1 » Fri Feb 01, 2019 4:32 pm
Doesn’t a failing cat usually give an eggy smell? But yes let’s hope it isn’t that, I’m betting it’s another ‘engine out job’.
A friendlier mot tester could be the easiest solution here :sekret:
Ajc
Post by Ajc » Fri Feb 01, 2019 6:09 pm
It is possible too get the cats out without dropping the engine , but it does still involve dropping the back end of the sub frame down and a really long extension bar .
Mine is soon too have no cats at all , so I wont have to worry . I work at a place that does mot's now :thumbs:
Cheers Al
Ben_r1
Post by Ben_r1 » Mon Feb 11, 2019 11:26 am
I was quoted for an engine out job to fit a pair of decats on mine as the specialist was adamant it’s near impossible to remove the bolts without the studs snapping.
Mark-RS
Post by Mark-RS » Mon Feb 11, 2019 7:27 pm
Oil change and Plug change and the readings are now within normal levels.
Back in tomorrow for the retest.
Users browsing this forum: srichards and 86 guests
