Did I hear there was a cheap fuel pump going?uplandsway wrote: ↑Wed Jan 30, 2019 11:16 amMike,
You know you wanna remap.
I have spare fuel pumps for you too when they arrive from US (dont ask), exactly the same as what MRC supply i just tried to get cheaper and failed.
will be available anyhow
The Mapping coin
- Toffeebananas
- 1st Gear
Re: The Mapping coin
- uplandsway
I will have spare fuel pumps x 2 when they arrive, same as MRC and alike supply.Toffeebananas wrote: ↑Wed Jan 30, 2019 12:13 pmDid I hear there was a cheap fuel pump going?uplandsway wrote: ↑Wed Jan 30, 2019 11:16 amMike,
will be available anyhow![]()
Genuine reason for sale:- I bought cheaper elsewhere, they now stuck in customs and they aint gonna be there for my stage 2 tune, had to get MRC to pull me out the <beep> and they have supplied
Cant say for sure when they are gonna be available but they are shipped and on way..days, weeks or poss a month.
First come first served. they are circa £400 retail each, you obviously require 2.
That the pumps anyhow https://autotech.com/mm5/merchant.mvc?S ... 0-127-101K
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
- uplandsway
You must be located pretty close to me as thats just through the tunnel from my end, performance centre in Sunderland is good for dyno and the lads are sound https://www.performance-centre.co.uk/gsc wrote: ↑Wed Jan 30, 2019 11:18 amSo did this at the weekend, currently APR stage 1 with their catted Downpipes mated to OE sports exhaust with resonators and muffler removed plus Piper Ross filter. I haven’t messed with plugs, pumps or injectors.
I’ve had this set up on the car for just over 8 months but never tested what difference there was after having just the ECU file. With the file only it was 680bhp and 1025NM.
Now 722bhp and 1104NM / 815ft lbs.
Nice RS7 too
Cheers,
Stevie F
Stevie F
Performance Centre is where I got the initial stage 1 ECU file figures measured but it is in the land of the unwashed and JM Imports is just up the road from me.uplandsway wrote:You must be located pretty close to me as thats just through the tunnel from my end, performance centre in Sunderland is good for dyno and the lads are sound https://www.performance-centre.co.uk/gsc wrote: ↑Wed Jan 30, 2019 11:18 amSo did this at the weekend, currently APR stage 1 with their catted Downpipes mated to OE sports exhaust with resonators and muffler removed plus Piper Ross filter. I haven’t messed with plugs, pumps or injectors.
Nice RS7 too
Sent from my ONEPLUS A6013 using Tapatalk
- uplandsway
I feel your pain.gsc wrote: ↑Wed Jan 30, 2019 1:40 pmPerformance Centre is where I got the initial stage 1 ECU file figures measured but it is in the land of the unwashed and JM Imports is just up the road from me.uplandsway wrote:You must be located pretty close to me as thats just through the tunnel from my end, performance centre in Sunderland is good for dyno and the lads are sound https://www.performance-centre.co.uk/gsc wrote: ↑Wed Jan 30, 2019 11:18 amSo did this at the weekend, currently APR stage 1 with their catted Downpipes mated to OE sports exhaust with resonators and muffler removed plus Piper Ross filter. I haven’t messed with plugs, pumps or injectors.
Nice RS7 too
Cheers,
Stevie F
Stevie F
- uplandsway
There WAS, now SOLDToffeebananas wrote: ↑Wed Jan 30, 2019 12:13 pmDid I hear there was a cheap fuel pump going?uplandsway wrote: ↑Wed Jan 30, 2019 11:16 amMike,
Cheers,
Stevie F
Stevie F
gsc wrote: ↑Wed Jan 30, 2019 1:40 pmPerformance Centre is where I got the initial stage 1 ECU file figures measured but it is in the land of the unwashed and JM Imports is just up the road from me,uplandsway wrote:Hgsc wrote: ↑Wed Jan 30, 2019 11:18 amSo did this at the weekend, currently APR stage 1 with their catted Downpipes mated to OE sports exhaust with resonators and muffler removed plus Piper Ross filter. I haven’t messed with plugs, pumps or injectors.
Nice RS7 too
Performance center Seem a good outfit, I need a little more province for the RS6 for me personally maybe more just piece of mind rather than anything else. I will however take it over for a Dyno run and maybe for them to get a new airbox in like mikes, thing looks incredible . Airbox envy Mike
gsc, the 7 is looking great . And great figures she sounds a weapon! Are you seeming most of your torque gain mid range? Could you post your print out if possible gsc from the RR by any chance?
Spoke to DMS today, as with Others have said with there chosen mapper, I have used them twice now and had a good service with quality results so I'm just setting it up for the map hopefully within the next few weeks.
I'm also hearing that taking the ECU out and plugging in on the pins to code is a lot better with seeing the maps on plug in initially rather than straight in to the OBD, obvisiouly this is won't stand up if they start looking in to data as we know but I'll see what exactly what the diffrence is later when I've spoke to the techs .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
- uplandsway
Performance Centre for Dyno runsAnth wrote: ↑Wed Jan 30, 2019 2:22 pmgsc wrote: ↑Wed Jan 30, 2019 1:40 pmPerformance Centre is where I got the initial stage 1 ECU file figures measured but it is in the land of the unwashed and JM Imports is just up the road from me.uplandsway wrote:
Nice RS7 too
Performance center Seem a good outfit, I need a little more province for the RS6 for me personally .
gsc, the 7 is looking great . And great figures she sounds a weapon! Are you seeming most of your tourqe gain mid range? Could you post your print out if possible gsc from the RR by any chance?
Spoke to DMS today, as with Others have said with there chosen mapper, I have used them twice now and had a good service with quality results so I'm just setting it up for the map hopefully within the next few weeks. I'm also hearing that taking the ECU out and plugging in on the pins to code is a lot better go seeing the maps on plug in initially rather than straight in to the OBD, obvisiouly this is won't stand up if they start looking in to data as we know but I'll see what exactly what the diffrence is later when I've spoke to the techs .
Cheers,
Stevie F
Stevie F
Will be interesting to see the printouts.
Just an observation having stood and watched Doug on the MRC Dyno - he always does several runs and tweaks various of the variables in the map to get the best curve etc as he does so. I guess many of the map first, dyno later, suppliers don't do this fine tuning.
Personally I like the fact that the map is done to suit me and my car.
Print out as requested, decent curvature. Figures based on 15% drivetrain loses
Thing is Dave, on stage 1 I doubt the gains you'd get from custom tuning over standard / generic are worth the time or effort, definitely won't feel them. Stage 2+ I can understandDaveperc wrote:Will be interesting to see the printouts.
I've been told that a number of times . Maybe squeeze a few HP extra but unnoticeable, the bespoke tune will still have athe base map just adjusted slightly, it's not some specific map just for that individual car from scratch .gsc wrote: ↑Wed Jan 30, 2019 3:13 pmThing is Dave, on stage 1 I doubt the gains you'd get from custom tuning over standard / generic are worth the time or effort, definitely won't feel them. Stage 2+ I can understandDaveperc wrote:Will be interesting to see the printouts.
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
- uplandsway
Anth wrote: ↑Wed Jan 30, 2019 2:22 pmgsc wrote: ↑Wed Jan 30, 2019 1:40 pmPerformance Centre is where I got the initial stage 1 ECU file figures measured but it is in the land of the unwashed and JM Imports is just up the road from me,uplandsway wrote: H
Nice RS7 too
Performance center Seem a good outfit, I need a little more province for the RS6 for me personally maybe more just piece of mind rather than anything else. I will however take it over for a Dyno run and maybe for them to get a new airbox in like mikes, thing looks incredible . Airbox envy Mike![]()
Have messaged you fella.
Cheers,
Stevie F
Stevie F
Evening all,
Ok RS6 is with DMS tomorrow for stage 1, I'm also doing the Sparks to uprated , although I don't think it has to be done more I ordered them and they need using !
Car is being taken to 720bhp and aprox. 950nM flywheel . So huge really in the world of performance gains for the RS6 I didn't come close on the 911.
Once complete I will do a full review, I have chosen DMS as they have been around for many many years, I have used them before, and the sheer amount of prestige vehicles they deal with on a daily basis, I belive there RS maps will be of quality I do have some stats I've been sent over from Santa Pod with the same software used from DMS , the times are impressive to say the least. I'll post shortly with them .
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
DMS Tuned RS6 C7
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
