Rear brake pads
alexrs6plus
Rear brake pads
Post by alexrs6plus » Mon Jul 17, 2017 9:47 pm
I have been unable to find any info on these via the search function.
Does anyone know the product code for these and do audi use Brembo rear pads?
Also does anyone know the best place to buy these plus price?
Thanks in advance. :thumbs:
Re: Rear brake pads
Post by MikeFish » Wed Jan 23, 2019 9:18 pm
I'm looking for rear pads. Options so far are:
OEM
Ferodo DS2500
Brembo ones from Euro Car Parts
OEM; can't be bothered to go into a dealers and order a set and feel one of the aftermarket options could be better.
Ferodo; I'd have probably gone with Ferodo but they don't have wear sensors and the photos of the pads are generic photos with no mention of the screws or retaining clips that the other pads come with.
Brembo; Not sure if the Brembo's are OEM or better (or worse?). Thought OEM were TRW.
Are there any other good options?
Re: Rear brake pads
Post by MikeFish » Sat Jan 26, 2019 8:45 pm
No one tried any aftermarket rear pads?
DaytonaMatt
Re: Rear brake pads
Post by DaytonaMatt » Mon Jan 28, 2019 1:44 pm
On my invoice on collection:
U4G0 615 601 E was "637094/BRAKE DISC"
U4G0 698 452 K was "637094/BRK LINING"
LeeRS6
Re: Rear brake pads
Post by LeeRS6 » Sat Feb 02, 2019 11:56 am
What did you go for in the end, mine are due soon
Re: Rear brake pads
Post by MikeFish » Sat Feb 02, 2019 9:53 pm
Still haven't decided. Probably just go for OEM.
shanek
Re: Rear brake pads
Post by shanek » Sun Feb 03, 2019 9:45 pm
I installed the Brembo ones in the rear. Had no issues with them and seemed to work as well or better than the standard ones with no squeal apparent in the time I had it. Also a little less brake dust than OEM.
I also had the DS2500's on the front axle as you do mike. Seems a good combo.
P.S. Mike, you are correct that OEM are TRW.
Re: Rear brake pads
Post by MikeFish » Sun Feb 03, 2019 9:58 pm
Thanks Shanek.
Re: Rear brake pads
Post by MikeFish » Sun Feb 03, 2019 10:13 pm
Just ordered the Brembo ones from ECP. They have a 37% discount at the moment so they went from £94 to £59. Bargain.
morski
Re: Rear brake pads
Post by morski » Mon Feb 04, 2019 2:17 am
Try their sister company as well next time carparts4less sometimes works out cheaper than ecp even with the discount code
LeeRS6
Re: Rear brake pads
Post by LeeRS6 » Mon Feb 04, 2019 8:17 am
Good to know, what are they like to fit, other than resetting the callipers via VCDS anything else that needs doing?
LeeRS6
Re: Rear brake pads
Post by LeeRS6 » Mon Feb 04, 2019 8:58 am
morski wrote:Try their sister company as well next time carparts4less sometimes works out cheaper than ecp even with the discount code
Thanks nice tip, worked out £47 delivered for the Brembos
Re: Rear brake pads
Post by MikeFish » Mon Feb 04, 2019 9:05 am
Wow that a super cheap.
Toffeebananas
Re: Rear brake pads
Post by Toffeebananas » Tue Feb 05, 2019 8:30 pm
Resetting the callipers via VCDS? Can I ask what that means please?
Re: Rear brake pads
Post by MikeFish » Tue Feb 05, 2019 8:40 pm
You need VCDS to wind the rear calipers back in.
