OEM Carbon Fibre Wing Mirrors
For those with factory installed carbon caps, do you still have heated glass facility? I suspect mine are on the blink because this morning with it being fairly icy I distinctly noticed they do not clear at all, even with front and rear screen demisters on.
Sent from my ONEPLUS A6013 using Tapatalk
Re: OEM Carbon Fibre Wing Mirrors
Yep have heated glass.gsc wrote:For those with factory installed carbon caps, do you still have heated glass facility? I suspect mine are on the blink because this morning with it being fairly icy I distinctly noticed they do not clear at all, even with front and rear screen demisters on.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Hmm, thought so, best see an auto spark then!rtd wrote:Yep have heated glass.gsc wrote:For those with factory installed carbon caps, do you still have heated glass facility? I suspect mine are on the blink because this morning with it being fairly icy I distinctly noticed they do not clear at all, even with front and rear screen demisters on.
What position is your micro switch in?
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
As above, they don’t work with demisters. Drivers’s mirror switch has to be in automatic heating position (5 o’clock from memory).
Yep, in heating position, not working
Fault fixed, loose fuse of all things, not sure how that happened as I’ve been nowhere near the fuse box since I bought it!
Users browsing this forum: Google [Bot] and 67 guests
