Bonnet gap!!
MrRSB7
Bonnet gap!!
Post by MrRSB7 » Wed Jan 16, 2019 11:19 pm
Helloooo!
I am getting pee’d off with this gap below the centre of my bonnet, pretty sure that is not supposed to be like that, although half the rs4’s I see have it...... is there anyway to fix this without taking it to a body Shop??
Many thanks
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
FrazerD
Re: Bonnet gap!!
Post by FrazerD » Wed Jan 16, 2019 11:52 pm
I would say the gap on yours is fairly small. Mine is on the larger side and waiting until it goes to MRC before doing anything about it. There’s a screw type stop either side of the grill that the bumper sits on and it’s these that you need to adjust to reduce the gap.
Cheers :thumbs:
Re: Bonnet gap!!
Post by Ian_C » Thu Jan 17, 2019 1:58 am
What on earth is going on with that plate?! You are definitely getting a full house on the illegal plate score card there!! Begging to have your butt shafted by a bored copper in a bad mood:
viewtopic.php?f=121&t=115113&start=285
MrRSB7
Re: Bonnet gap!!
Post by MrRSB7 » Thu Jan 17, 2019 8:18 am
I haven’t seen a police car in our town since 2017, should be ok for a bit 😂
FrazerD
Re: Bonnet gap!!
Post by FrazerD » Thu Jan 17, 2019 10:07 am
Regardless if you get stopped or not, what’s the crack with the spacing?
Cheers :thumbs:
coffey555
Re: Bonnet gap!!
Post by coffey555 » Thu Jan 17, 2019 1:17 pm
I think you need to slacken off the bolts holding the front bumper on first before turning the adjusters, otherwise they break.
Misano Red RS4 B7 Avant
KernowPete
Re: Bonnet gap!!
Post by KernowPete » Thu Jan 17, 2019 9:43 pm
Yeah I'm sure there's a 'how to' on here somewhere. There is a certain amount of adjustment using the two adjusters but I found with mine I also had to slacken off the retaining fixtures for the whole bumper, some of which are in the wheel arches and a pita to get to. Even then I never managed to get it perfect, certainly no better than in the OPs photo!
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
AlexB7RS4
Re: Bonnet gap!!
Post by AlexB7RS4 » Sat Feb 16, 2019 1:10 pm
If you have a search you'll find a couple how tos. May also need to loosen off the headlights. It's a prick of a job, need a long handled torx for it as well.
Yours isn't that bad though. You might get it a little better but likely not a lot.
MrRSB7
Re: Bonnet gap!!
Post by MrRSB7 » Tue Feb 19, 2019 12:56 am
Maybe is just me,but I thought it looked pretty bad from these angles
Kenny147
Re: Bonnet gap!!
Post by Kenny147 » Tue Feb 19, 2019 2:02 am
I’ve had to take mine off a few times, so I’ve gotten quite good at getting it close but I still can’t get it down to the 5mm the manual says it should be. WTF?
It looks like you’re bumper can go up a few mm’s as there’s a gap below the headlights. You’ll need to loosen the 3 headlights screws on each side and all the bumper mounting points before you adjust the bumper. It’s a pain to get right on your own and much easier if you have some help.
Check your pm’s.
Users browsing this forum: No registered users and 109 guests
