Removing front RS6 badge (grille)
Re: Removing front RS6 badge (grille)
Yes that's the one. Hmm might exain why it's so hard to release.
Hi Mike,
Did you ever get the badge off? If so, what's the trick?
Thanks,
Thanks,
David
No not yet. But I need to take the grille off at some time so will probably leave it until then.
However, I know what the back of the badge looks like so it should come off but I just can't seem to release it.
Finally took some time in the zero degrees this morning to figure out why this badge wouldn't budge. Finally did and finally got it off. The following pics should explain all...
Basically the badge is clipped into the holding bracket behind the grille. The tabs need to be squeezed together (towards the badge centre) to release. All very well providing some bright spark hasn't also coated them in rock hard glue.
In my case I was able to chip away enough glue on one tab to get it to release but try as might I could get the second one to release hence the damage as I ended up just twisting it out. I wanted it out anyway, so will buy a new one for when (if) I sell the car.
Anyway, hope that helps.
David
Nice one Dave. That looks like mine except I don't have a any glue on mine. I managed to poke my phone down between the grille and radiator to take some photos. It looks like yours but without the glue. But it didn't help me remove it still.
Mike
I’m sure pre facelift and facelift badges are slightly different clip wise?
I have a carbon badge on my pre FL car and it wouldn’t fit on my FL!
Why I don’t know!!
Why I don’t know!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Yes Chris that's right. I have a spare badge from a pre facelift grille and the back is held on with those little metal clips.
Pre facelift:
Interesting as my car is pre-facelift. No metal clips anywhere. Perhaps they just had different fixings from different suppliers and used them as they were supplied?
David
Definitely different types of fitting as I wanted mine off and Cardiff Audi said £££ to take off as it was a different fitting than pre FL - I didnt bother....
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
Inspired by this fresh talk of badge removal I attacked my badge last night with a big screwdriver. I used it to push the tab back on the left hand side through the honeycomb whilst pulling the badge forward and it popped it. Did similar on the other side and out it came. Even managed to retrieve the back bracket from inside the grille.
- uplandsway
Pitty them bloody blades weren't as easy Mike eh !!
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Stevie F
The flaps were easy enough when I took it to a garage.
Users browsing this forum: No registered users and 44 guests
