Wheel spacers
Wheel spacers
Hi
I’ve added spacers to my standard wheels, with the standard tyres....
The car is lowered on bilstein suspension from what I can tell.... a bit too low in my opinion...... now I’ve added the spacers the tyres rub in the arches....
Can i raise the ride height of the suspension?? Is this an easy/inexpensive task?? the wheels look really good I don’t want to lose the spacers.
Many thanks
Many thanks
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
Re: Wheel spacers
Fronts a doddle
Rears are a bit more awkward expect skin loss
I assume you fitted 10mm spacers ?
If so drop to 8mm problem solved
Re: Wheel spacers
20 mm all round
Re: Wheel spacers
I’m surprised you can move the car with 20mmMrRSB7 wrote:20 mm all round
I doubt anyone uses that size
8mm is the desired size
Re: Wheel spacers
That’s what they recommended in the garage where they powder coated the wheels
Re: Wheel spacers
Either they meant 20mm per axle ie 10mm per side or they have no idea.
Re: Wheel spacers
I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in
Re: Wheel spacers
You bought another one!!!! Always knew you wouldFatneck73 wrote:I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: Wheel spacers
Yeah..wasn’t planning on it but couldn’t resist.
Re: Wheel spacers
Re: Wheel spacers
This don’t look looks 20mm spacers to be honest. Perhaps it’s 20mm per axle? Where did you buy the spacers?
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: Wheel spacers
Yes maybe your right...... the garage did supply and fit, he mentioned 20mm .... I assumed it was 20 each
Looking at the spacer , it’s no way near 20 mm
Re: Wheel spacers
Why not just remove your spacers, less hassle.
Personally I don't get spacers unless you really need them due to aftermarket wheels.
Re: Wheel spacers
Burn me
Users browsing this forum: Google [Bot] and 192 guests
