Wheel spacers
MrRSB7
Wheel spacers
Post by MrRSB7 » Thu Dec 27, 2018 10:11 am
Hi
I’ve added spacers to my standard wheels, with the standard tyres....
The car is lowered on bilstein suspension from what I can tell.... a bit too low in my opinion...... now I’ve added the spacers the tyres rub in the arches....
Can i raise the ride height of the suspension?? Is this an easy/inexpensive task?? the wheels look really good I don’t want to lose the spacers.
Many thanks
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
andyg72
Re: Wheel spacers
Post by andyg72 » Thu Dec 27, 2018 10:40 am
Fronts a doddle
Rears are a bit more awkward expect skin loss :)
I assume you fitted 10mm spacers ?
If so drop to 8mm problem solved
MrRSB7
Re: Wheel spacers
Post by MrRSB7 » Thu Dec 27, 2018 10:55 am
20 mm all round
andyg72
Re: Wheel spacers
Post by andyg72 » Thu Dec 27, 2018 10:58 am
MrRSB7 wrote:20 mm all round
I’m surprised you can move the car with 20mm
I doubt anyone uses that size
8mm is the desired size
MrRSB7
Re: Wheel spacers
Post by MrRSB7 » Thu Dec 27, 2018 11:34 am
That’s what they recommended in the garage where they powder coated the wheels 😂😂😂
Re: Wheel spacers
Post by MikeFish » Thu Dec 27, 2018 12:24 pm
Either they meant 20mm per axle ie 10mm per side or they have no idea.
Fatneck73
Re: Wheel spacers
Post by Fatneck73 » Thu Dec 27, 2018 12:30 pm
I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in 😂😂😜
Fatneck73
Re: Wheel spacers
Post by Fatneck73 » Thu Dec 27, 2018 3:25 pm
Although, sits pretty nice (when not loaded up).
pule333
Re: Wheel spacers
Post by pule333 » Thu Dec 27, 2018 11:49 pm
Fatneck73 wrote:I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in ImageImageImage
You bought another one!!!! Always knew you would ImageImage looks really really good!!!
RS4 B7 aka Vinnie
Fatneck73
Re: Wheel spacers
Post by Fatneck73 » Fri Dec 28, 2018 8:39 am
Yeah..wasn’t planning on it but couldn’t resist. 😂😂😂. Showing above so Op can see that Bils PSS9’s and 8mm’s work ok albeit not sure what drop I’ve got.
MrRSB7
Re: Wheel spacers
Post by MrRSB7 » Fri Dec 28, 2018 2:09 pm
pule333
Re: Wheel spacers
Post by pule333 » Fri Dec 28, 2018 2:14 pm
This don’t look looks 20mm spacers to be honest. Perhaps it’s 20mm per axle? Where did you buy the spacers?
RS4 B7 aka Vinnie
MrRSB7
Re: Wheel spacers
Post by MrRSB7 » Fri Dec 28, 2018 2:24 pm
Yes maybe your right...... the garage did supply and fit, he mentioned 20mm .... I assumed it was 20 each
Looking at the spacer , it’s no way near 20 mm 🤦🏻‍♂️
Covkiller
Re: Wheel spacers
Post by Covkiller » Fri Dec 28, 2018 3:27 pm
Why not just remove your spacers, less hassle.
Personally I don't get spacers unless you really need them due to aftermarket wheels.
Covkiller
Re: Wheel spacers
Burn me :FIREdevil:
