Braking Problem In The Wet
bn8959
Re: Braking Problem In The Wet
Post by bn8959 » Mon Dec 17, 2018 10:31 am
superlightr wrote:
Mon Dec 17, 2018 9:01 am
“To stop the feeling of having a long pedal when you are really working the brakes we fitted a booster which brings the pedal back up when it’s getting long – sometimes it can come back right to the top of the pedal travel.”
but that's not true - this happened to me on a normal slow commute in - I gently touched the brakes and full on braking came on for a second. Was not honing or driving fast in anyway whatsoever on the whole journey. There was no long pedal/fade or anything it was emergency braking from a light touch. Had only happened a few times but it did happen. I don't accept Reil explanation as its not what happened to me or what it sounds like to others here.
standard brakes. with regards to ceramics - I don't belive they can pick up so much water steel or cermics that you get that emergency brake - never had it on any other car either with ceramics or steels - DB9 M5 E63 AMG, 911tt's just the RS6
This is exactly what Ive experienced too.
Other similar discussions/symptoms here:
viewtopic.php?f=76&t=127418&p=874285#p874285
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
r45hRS6
Post by r45hRS6 » Mon Dec 17, 2018 1:35 pm
Daveperc wrote:
Thu Dec 13, 2018 1:14 pm
That certainly doesn't sound right!
I have the opposite problem when running in the wet - the wipe function doesn't really dry the brakes so when braking after a prolonged run in the wet they are initially (1-2 secs) not very effective at all - the result, much like you, is that you brake harder and then they suddenly catch much harder than you want. I have ceramics BTW and am told that the frequency etc of the wipe is different but in all other respects the system is the same.
My solution so far has simply been to ensure I brake early and fairly frequently to avoid the problem. I may also have to train myself to go back to cadence braking like in the old days.
Can the brake functioning (and wiping) be monitored in real time with VCDS?
Hi Guys,
After 5 months of ownership and much spirited driving i must say I've never had any issues with the braking until this weekend whilst on a 400 mile round trip up north from London in the loving arms of storm diedre. It was only pouring rain but the braking system in my opinion was a little slow to react compared to previous reaction times. Obviously the copious amounts of water i expected was the cause.. car remained planted through water and did not aquaplane BUT on one occasion i tapped the brake gently to shed a little speed and the damn thing nearly did an emergency stop... A complete WTF happened moment for me. Its happened only once but scared the living daylights out of the family.
BTW: i don't have ceramics and i suspect i have experienced what Chris has mentioned above. I'll definitely be more aware of this function/issue with the braking system. Which is it?
Sedge5
Post by Sedge5 » Mon Dec 17, 2018 9:34 pm
RS6chris! wrote:
Thu Dec 13, 2018 5:38 pm
I was in really heavy rain at high speeds....hit the pedal and for a few secs(or so it seemed) absolutely <beep> all!!
I <beep> me self then they bit!!
I have ceramics also
Do you also get these annoying 'screams' from the ceramics, especially when wet?..... l always look around to see if anyone has heard me, but then, of course, l have even woken up the neighbour's obese dog....!
RS6 C7 PE - current
S6 C7 Avant - too hesitant, not enough power
A6 C7, 2.0 TDI......aghhhhh
A3 , 2.0 BE, tdi, yeahhh...
Daveperc
Post by Daveperc » Mon Dec 17, 2018 10:04 pm
They were very noisy when they were new, but seem to have bedded down now. Don't think they are any noisier when wet, though they are a bit noisy when they have been put away wewt, and then restarted the next day.
Mr Footlong
Post by Mr Footlong » Fri Dec 21, 2018 11:05 pm
Weird, I did the best part of 7 hours driving in Monsoon weather most of the time last weekend and can't recall any problems with my steel brakes. Will keep an eye out but it was at least 3 hours each way in that weather.
Current:
Gone:
Paulm
Post by Paulm » Sat Dec 22, 2018 6:29 pm
I had this on my 2015 RS6 twice in 6k miles when it was new and so far once on the RS7. For me it happens with breaking from speed going downhill. Never happened in the S7. weird and scary the first time it happened. Cant remember if it was wet or not.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
Scotty C
Post by Scotty C » Sun Dec 23, 2018 1:34 pm
Brake servo testing tool arrives at dealers on Monday, having waited two weeks for it, so maybe that will highlight something, although I doubt it will. For now I'm raking up some heavy mileage in a Q7 S Line they've given me - it's obviously no comparison but at least the brakes work as they should,
Current: 2019 BMW Alpina - B5 Bi Turbo Touring
Current: 2014 Land Rover Defender 110 All Black
Previous: 2017 RS6 Performance - Misano Red with Black Styling Pack
Previous: 2014 RS6 - Misano Red
Previous: 2004 S4 Avant - Nogaro Blue
Previous: 2001 S3 Absolute Red
Covkiller
Post by Covkiller » Wed Dec 26, 2018 12:09 pm
If the Audi servo test doesn't find anything I would first fit braided hoses and if this doesn't work I'd also fit front Ferodo DS2500 pads
Post by MikeFish » Wed Dec 26, 2018 3:56 pm
I have this combo and don't have the problem. Can't say I had it before this combo though.
superlightr
Post by superlightr » Wed Dec 26, 2018 9:03 pm
it felt like a software issue to me - the computer was applying full braking for a split second rather than a physical defect.
Tadass910
Post by Tadass910 » Wed Dec 26, 2018 9:30 pm
Guys I think you all a little paranoid, just drive and enjoy your cars)
Paulm
Post by Paulm » Fri Dec 28, 2018 7:08 pm
obviously never happed to you then. Trust me its not nice when it does.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Scotty C
Post by Scotty C » Wed Jan 02, 2019 2:39 pm
And certainly not nice, or paranoia related, when it is continuous for two days solid...
Brake Servo Tool has arrived and the car is being looked at today so will update as soon as I hear anything...
Scotty C
Post by Scotty C » Tue Jan 08, 2019 12:06 pm
Well surprisingly the brake servo test has revealed nothing other than it is working perfectly normal. Audi technical have no other suggestions as to what it may be other than to keep road testing the car. Without wishing for bad weather, I have suggested a 30 minute at motorway speed road test with wipers on may trick the car in to believing it is raining and give them the answers they are unable to find just by looking on a computer...
Paulm
Post by Paulm » Tue Jan 08, 2019 2:27 pm
keep us posted would be good to find the cause
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Users browsing this forum: No registered users and 62 guests
