Vibration 75-80mph
Re: Vibration 75-80mph
Sorry to hear that. If replacing them avoid Audi and go to ebay.de There is a new set of Performance alloys and tyres on there for £2600, and normal versions are cheaper.
Or get some 20s - they are problem free (within reason).
Vicious... I had two and thought that was bad.
Current: 2019 BMW Alpina - B5 Bi Turbo Touring
Current: 2014 Land Rover Defender 110 All Black
Previous: 2017 RS6 Performance - Misano Red with Black Styling Pack
Previous: 2014 RS6 - Misano Red
Previous: 2004 S4 Avant - Nogaro Blue
Previous: 2001 S3 Absolute Red
- 1st Gear
Front 2 minor apparently, rear nearside a little more so as evidenced by quite a few weights.
Audi saying get them all looked at, keep 'best 2' and buy 2 new, however as the vibration currently is really quite minor I am tempted to either leave it, or have them repaired. If I were to ever replace 2, I would in all honesty consider going an aftermarket route
Has anyone had a repair done?
Road force balancing with rim matching will give the best ride possible with bent rims. Way better than normal balancing.
I wince (and panic) every time l hit or drive over a bump and/or pothole. Have heard horror stories about wheel buckling.... what has caused your 3 wheels to buckle if you can recall?
RS6 C7 PE - current
S6 C7 Avant - too hesitant, not enough power
A6 C7, 2.0 TDI......aghhhhh
A3 , 2.0 BE, tdi, yeahhh...
- 1st Gear
No idea - happens above NSL so not picked up pre purchase. Noticed it shortly thereafter. So before my time
I had a buckled wheel and had it repaired for about £170. Cheaper than a replacement.
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
1.4 Fiesta (Silver)
I have got the same issue I think. Vibration felt at the same speeds but not all the time.. not through the steering wheel though..
- 1st Gear
Just thought I should follow up....
Took it to a local place Audi use - 4 wheels all slightly buckled, straightened out in the morning and now drives perfectly. Interesting the owner of the wheel place said his preference was to a slightly softer wheel as they bend and can be repaired, versus apparently a BMW issue where they tend to just crack
Interesting so they just straightened the wheels without a refurb?DaytonaMatt wrote: ↑Wed Feb 27, 2019 6:45 pmJust thought I should follow up....
- 1st Gear
When you say refurb, do you mean getting rid of parking damage etc? In which case yep - all they did was straighten. I do have a few dings on the wheels but none big enough to annoy me so I didn't ask for them to be done, and nor did they insist.
It was Autowerks in slough - must admit a thoroughly good outfit based on my experience
Users browsing this forum: No registered users and 83 guests
