20 inch wheels!
Re: 20 inch wheels!
Post by MikeFish » Thu Nov 29, 2018 4:48 pm
OK, so, the 20" RS6 C7 wheels will work with ceramics if you either drive an RS4 Allroad or if you are low but have lots of negative camber. Like a man with an orthopaedic shoe, I stand corrected.
Softishman
Re: 20 inch wheels!
Post by Softishman » Fri Nov 30, 2018 10:28 pm
Some camber is needed🤗 STERN controll arms front and 034MS rear camber arms.
My new spacers are 7mm aswell, 10mm on picture
@softishman on IG
Check out my RS4 there!
Re: 20 inch wheels!
Post by Ian_C » Sat Dec 01, 2018 11:44 am
Softishman wrote:
Thu Nov 29, 2018 10:35 am
Wow. :kissmyrings:
dhali
Re: 20 inch wheels!
Post by dhali » Sat Dec 01, 2018 7:39 pm
Graphics not my thing but none the less amazing work gone into the car .
BenHol
Re: 20 inch wheels!
Post by BenHol » Sat Dec 01, 2018 11:52 pm
MikeFish wrote:OK, so, the 20" RS6 C7 wheels will work with ceramics if you either drive an RS4 Allroad or if you are low but have lots of negative camber. Like a man with an orthopaedic shoe, I stand corrected.
I wouldn’t say mine is too high.. although nowhere near as low as above.
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
Re: 20 inch wheels!
Post by MikeFish » Sun Dec 02, 2018 12:08 am
Were you at ADI this year?
BenHol
Re: 20 inch wheels!
Post by BenHol » Sun Dec 02, 2018 10:24 pm
Busted. yes I was.
The ceramics I fitted are adapted from a R8 so the calliper has a different offset to the B7 ceramics. But I do have 8mm spacers on at the mo. It would probably be ok with 5-6mm spacers but wanted to be hubcebtric so stuck with the 8mm.
Im not sure what softishman’s are adapted from, do you know? But as they’re 400mm rotors the callipers will sit 10mm further out of the concave then mine hence they may fit easier. Would be interested to know what spacers are on that one too?
Re: 20 inch wheels!
Post by MikeFish » Sun Dec 02, 2018 10:59 pm
Yes, the front are from an S6/S7. Not sure what the rear are from; possibly the same.
Softishman
Re: 20 inch wheels!
Post by Softishman » Tue Dec 04, 2018 1:11 pm
My brakes are from S6/S7.
I have a 4mm spacer behind the disc (and grinded down caliper bracket 0,4mm) do make it fit.
On top of that i will use a special 7mm hubcentric in and outside spacer (to the disc and the wheels). On the pictures i testfitted them with a 10mm spacer. So later ot will bu 3mm further in.
Hope that answers your qeustions?!
More pics on the car and brakes on Instagram @softishman
The graphics is gonna be removed later... going back to the clean look😎
@softishman on IG
lengster1
Re: 20 inch wheels!
Post by lengster1 » Sun Dec 23, 2018 7:41 pm
Did you get sorted with a set? I’ve just bought a b7 on 20” rotors that I might do a deal with if I don’t let em go with the car.
MrRSB7
Re: 20 inch wheels!
Post by MrRSB7 » Sun Dec 23, 2018 9:39 pm
But for now I’ve decided to get the existing OEM 19’s powder coated
Just come back from the garage 💦💦💦💦
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
Fatneck73
Re: 20 inch wheels!
Post by Fatneck73 » Fri Dec 28, 2018 8:46 am
Piccys?
WRS4
Re: 20 inch wheels!
Post by WRS4 » Sun Jan 06, 2019 3:19 pm
hi, I have only just seen this post but all I would advise is NEVER buy 20" rims, I had some on my M3 AND NOW MY RS4 and I cracked 2 rims on the m3 and 3 rims on my rs4. No not due to my driving but the fact our roads are so poor these days its a joke. That and the fact a 20" rim has far slimmer tyre profile which takes the cushion out of the side wall then as soon as you hit a pot hole there is no give and the rim cracks. I still have 20" on my car but if I could turn back the clock I would never add 20" rims again to any car. And I get we all think it will never happen to us, I thought the exact same thing not ever having a puncture in over 25 yrs, but 5 cracked rims since moving up to a 20" says it all really
Sprint Blue RS4 - 20" X 10J 3DSM Wheels - Carbon Front Splitter - Carbon Rear Diffuser - H & R Anti Roll Bars - Bilstein Adjustable Shocks - Milltek Exhaust System - De Catted - Valve Removed - MRC Stage 2 Re-Map - 480 bhp
Re: 20 inch wheels!
Post by MikeFish » Sun Jan 06, 2019 9:17 pm
I had 20" on my RS4 for years without a single issue. And not have 21s on my RS6 again without issues.
FaisalJ
20 inch wheels!
Post by FaisalJ » Sun Jan 06, 2019 10:15 pm
WRS4 wrote:hi, I have only just seen this post but all I would advise is NEVER buy 20" rims, I had some on my M3 AND NOW MY RS4 and I cracked 2 rims on the m3 and 3 rims on my rs4. No not due to my driving but the fact our roads are so poor these days its a joke. That and the fact a 20" rim has far slimmer tyre profile which takes the cushion out of the side wall then as soon as you hit a pot hole there is no give and the rim cracks. I still have 20" on my car but if I could turn back the clock I would never add 20" rims again to any car. And I get we all think it will never happen to us, I thought the exact same thing not ever having a puncture in over 25 yrs, but 5 cracked rims since moving up to a 20" says it all really
Like Mike - I have 20” wheels on my RS4, and previous set were 20s too. Been fine.
WRS4 - what wheels were they? You may have just been unlucky. No guarantee that OEM wheels wouldn’t buckle or crack too
2007 RS4 B7 Avant
Users browsing this forum: No registered users and 118 guests
