RS4 B9 picture thread
2.9 V6 24v TFSI - 444 bhp
0xSam
Re: RS4 B9 picture thread
Post by 0xSam » Mon Nov 12, 2018 7:39 pm
Where are you guys getting the black audi rings from?
-Audi RS4 B9 | HRE P107 20" - Gloss Black
-Nissan GT-R MY2015
PieterZ
Post by PieterZ » Mon Nov 12, 2018 11:34 pm
You can find them on ebay.
All black B9 RS4
0xSam
Post by 0xSam » Tue Nov 13, 2018 8:26 am
Thanks!
-Nissan GT-R MY2015
Terminator_X
Post by Terminator_X » Tue Nov 13, 2018 8:40 am
I got mine from Fresh Mods UK.
TX.
Sent from my BBB100-2 using Tapatalk
Brooner
Post by Brooner » Tue Nov 13, 2018 10:36 am
Was the rear the correct size i found the ones on ebay they were smaller than oem
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
OU812
Post by OU812 » Thu Nov 15, 2018 12:42 am
Are the front rings easy enough to change ?
OU812?
Terminator_X
Post by Terminator_X » Thu Nov 15, 2018 1:11 am
Brooner wrote:Was the rear the correct size i found the ones on ebay they were smaller than oem
Ever so slightly smaller but not noticeable imho eg you can see it if both laid side by side but not when on the car.
TX.
s4tokyo
Post by s4tokyo » Thu Nov 15, 2018 9:59 am
@OU812, there are a few YouTube clips of how to change (front rings) ...... most are not pretty to look at but all get the job done.
This guy uses minimum tools that might scratch /dent the grill and so I attach this one FYI : https://www.youtube.com/watch?v=IJzh6aew6wE
Current :Sonoma Green. Ext Black Pack, Carbon 'Ext/Eng Cover/Int trim', Sports Exhaust, RS Sports Int., Pana Sunroof, Matrix Lights, Park & Drive Assist pkg., Speed limiter removed, Titanium-Anthracite 20".
Previous : B8.5 RS4 Daytona Gray
Previous : B8 S4 Ibis White
RS4John
Post by RS4John » Sun Nov 18, 2018 6:37 pm
Misano Red/Lunar silverImage
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
OU812
Post by OU812 » Sun Nov 18, 2018 6:59 pm
Beautiful!
Audimeister41
Post by Audimeister41 » Tue Nov 20, 2018 3:42 pm
This guy uses minimum tools that might scratch /dent the grill and so I attach this one FYI : https://.youtube.com/watch?v=IJzh6aew6wE
autocollants pour les voitures
aah good to see this vidéo ! its in my favorite for when i will have my RS ;)
Last edited by Audimeister41 on Mon Apr 08, 2019 1:03 am, edited 2 times in total.
AJ13
Post by AJ13 » Tue Nov 20, 2018 10:45 pm
AndyL wrote:
Mon Nov 12, 2018 6:15 pm
J88NOG wrote:
Mon Nov 12, 2018 9:13 am
AndyL wrote:
Thu Nov 08, 2018 8:33 pm
I have the standard 19's and have fitted 12mm spacers front and 15mm spacers rear, I have also removed the front fender screw. I have had zero rubbing issues with it, even when driven had down country lanes.
Thanks - good to know. Are you pleased with the stance now? Mine will be going on later in the week.
:nogarors4:
It is much better than stock, however it could probably do with another 2mm at the front and the rear to make it perfect.
Yeah, stance is a tough one. I will be swapping the twin spoke wheels for the 5 arm milled ones soon. So I will move to 15mm rear and 10mm front as the offset on the milled wheels is different (4mm close to the arches) so my overall track will then be 1mm less on each side on each corner.
I’m also going to run winter tyres.
Question though..... should I paint my milled wheels black? Or satin bronze? Or copper? Or satin gold?
Brooner
Post by Brooner » Wed Nov 21, 2018 4:12 am
The colour is a good question you may want to keep them standard for now then look at powder coating them if your not happy with the standard look
The satin bronze against the green could look great but a safe bet would be satin black
You just might have to take the leap and try the bronze and if its hidious change them to black
Markp
Post by Markp » Sat Dec 01, 2018 1:48 pm
J88NOG wrote:
Tue Oct 23, 2018 8:27 am
AJ13 wrote:
Mon Oct 22, 2018 6:44 pm
I have Sonamo and black. It looks 10 million times better in the flesh. But you need to either paint the wheels or swap them. The graphite colours clash with green and black.
And then there’s the spacing issue. I have 15mm front and 20mm back which is super aggressive but worth it.
The wheel spacing is a bit odd from factory - maybe there are some regs about wheels/tyres not falling outwith the overall footprint of the bodyshell - I seem to remember hearing that the little plastic fender sticking out from the rear wheel arch on some older models (A3/A5?) was designed to defeat that and allow wider track. That could be nonsense though.
Have you had any issues with rubbing at that spacing? I have the standard 19"s and have 12mm spacers to fit all round, but then I think they have 2mm less offset than the 20"s and so should be no problem.
Do you have a picture Andy? And who supplied the spacers, bolts, locking nuts etc?
Mark
AJ13
Post by AJ13 » Sat Dec 01, 2018 2:42 pm
I put H&R spacers on it that I got from Venom motorsports. Make sure you are clear that you have 66.5mm centres, they are the same spacers as you would put on the RS6.
Pictures attached.
Users browsing this forum: No registered users and 10 guests
