Revolution air intake
Stew
Post by Stew » Wed Nov 21, 2018 9:02 pm
Evening all has anyone a guide on fitting one off these ie do you leave the bottom half off the original air box as I am doing a caf as well your help would be greatly appreciated 👍
Re: Revolution air intake
Post by MikeFish » Wed Nov 21, 2018 10:40 pm
No get rid of the oem air box. Run a 102mm cold air feed straight up into the air filter.
RichieB
Post by RichieB » Mon Nov 26, 2018 11:48 am
As Mike says - fit a large CAF from behind the fog light grill (assuming you have aux radiator delete?)
My RS came with the Revolution intake and a small diameter CAF fitted so I upgraded to a larger one. I'll post some pics later but its pretty straight forward.
Post by MikeFish » Mon Nov 26, 2018 5:53 pm
Yeah the normal cold air feed fitted is about 89mm as that is a good match to the air box inlet but with the revolution air intake you have a much larger opening and more potential for heat soak so go as big as you can fit. I swapped my MRC fitted 89mm for a 102mm. You might be able to get next size up but I think 102mm was fairly tight.
RichieB
Post by RichieB » Mon Nov 26, 2018 11:45 pm
Heres a few random pics of my upgrade install -
45mm diameter feed removed ready for 102mm. My opinion is any larger would be struggle to fit
Inlet trumpet fitted
Engine bay bling
Covkiller
Post by Covkiller » Tue Nov 27, 2018 10:40 pm
Looks like a smart job. And I bet it sounds proper Nascar ?
:thumbs:
Stew
Post by Stew » Wed Nov 28, 2018 7:12 pm
Thanks guys for the reply’s yes have a 102 mm one was thinking off trying to make a heat shield to stop the heat from the manifold think I remember someone done it was wondering was it successfull ?
jonytek
Post by jonytek » Thu Nov 29, 2018 5:24 pm
Is this what you're referring to? viewtopic.php?t=91761
BUILD THREAD
IG: @bad_rs_4
RichieB
Post by RichieB » Thu Nov 29, 2018 10:32 pm
:thumbs:
Cheers. It does sound good - especially with the gutted pre cats and centre resonator delete. Still get the V8 rumble at low revs but then the higher up towards the redline it starts to scream :D
James1984
Post by James1984 » Fri Nov 30, 2018 1:27 am
Ive just used a ram-air pipe, its 100mm but is pvc instead of the usual neoprene and keeps its shape very well, its about £25 delivered with 2 alloy end pieces and 1m of ducting and i used exactly half, on a standard airbox.
Users browsing this forum: No registered users and 327 guests
