Cam chain tensioners/pads removal and replacement guide
Classik
Re: Cam chain tensioners/pads removal and replacement guide
Post by Classik » Fri Nov 09, 2018 11:07 am
Update : new measurements this morning. Short term phasing is between - 0.5 and +0.5 at idle on both bankd, and hoovers around - 20 under load. Both banks are tightly correlated meaning the difference between the 2 banks is always less than 2 degrees at most.
Long term phasing (group measurement 93) is even worse now: - 2°kw on bank 1, - 6°kw on bank 2 🤔
Could the position sensors be blamed for this?
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Post by Shoppinit » Fri Nov 09, 2018 12:15 pm
Déphaseur bloqué, innit.
Classik
Post by Classik » Fri Nov 09, 2018 12:32 pm
Much more clear now! 😉
The mechanical parts of the tensioner have been checked, meaning it can move and the spring has been compared ok against the other tensioner.
Post by bam_bam » Fri Nov 09, 2018 1:29 pm
Shoppinit wrote:
Fri Nov 09, 2018 10:22 am
...Might be a seized dephaser.
Sage.
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 09, 2018 1:57 pm
Or hallucinogenic drugs
Post by Shoppinit » Fri Nov 09, 2018 2:00 pm
Nutmeg. If taken in sufficient quantities it’s a hallucinogen.
Sage not so much.
Post by bam_bam » Fri Nov 09, 2018 2:02 pm
Yep, I took a whole bunch of it in prison, I've never been the same.
Post by Shoppinit » Fri Nov 09, 2018 2:04 pm
Suppository stylee?
Mr Footlong
Post by Mr Footlong » Fri Nov 09, 2018 4:00 pm
Suppository stylee?
As if there is any other way?
Current:
Gone:
Post by Shoppinit » Wed Nov 14, 2018 12:21 pm
So there is another option for these dephasers. There is a US company that makes replacements for about £300 each. I think I'd be happier with these replacement units than with a random ebay vendor.
https://www.summitracing.com/int/parts/ ... /overview/
Rockauto has one of them but not the other. Maybe they can get it for you. Never used Summit but believe they do pre-paid duty and shipping like Rockauto do.
Post by Shoppinit » Tue Nov 27, 2018 5:22 pm
You made any progress on this?
Classik
Post by Classik » Tue Nov 27, 2018 6:26 pm
Thanks for the follow up ! Actually not much progress on this front as such, but 1/I can confirm the short term phasing is at 0°at engine idle, and that both banks measure in a hankerchief under load which, to my my understanding, means the cam tensionners do their job properly (am I correct?) and 2/for the long term measurements my mechanics suspects he may have fasten one of those tensioning rolley a bit too much. Hall sensors could also be checked, I had to change them on my previous car (Atmos S6 C5) after strange phase readings. This will be checked again when I'll visit him again to mount my new wheels! ;)
Meanwhile am I wrong to assume I'm safe? A friend sent me this extract from Elsa stating I'm still within specs (-6...+6), admittedely by a very close margin.
Post by Shoppinit » Tue Nov 27, 2018 7:45 pm
You're right on the acceptable limit. You're safe, but haven't got optimal timing. Maybe some small power loss?
Classik
Post by Classik » Tue Nov 27, 2018 7:55 pm
This will be fixed foe sure, thanks for the advice, nevertheless it's good to know I won't break anything till then!
Mɐʇʇ
Post by Mɐʇʇ » Tue Nov 19, 2019 9:37 am
Just a quick addendum to Nobby's original post where he references the availability of aftermarket tensioners. Reviews/feedback on the aftermarket ones seems to be few and far between - however the 2 reviews I've found on ebay ones say avoid. So if you can't just replace the pads and need the full tensioner, go OEM would be my current view.
Users browsing this forum: Bing [Bot] and 55 guests
