Dont be naive, ecu remap visible by Audi, even if u install so called piggyback it’s also visible
TD1 code
Re: TD1 code
- 1st Gear
Re: TD1 code
Yeah right. You must be best mecanich in your country...? If you want i can send vid where you can see how this works. Same guy OSSI HARINEN my frend made my BMW M5 f10 2014 new program. (I change turbos etc. etc.) this option that i can flash bought (bmw m5 have 2 ecuboxes) ecus if i want. And yes. Bmw diagnostic ista cant able to see nothing after flashing ecus.
Re: TD1 code
Go to Audi dealer and let them scan it voila)FinlandRS6C7 wrote: ↑Fri Nov 23, 2018 12:27 amYeah right. You must be best mecanich in your country...? If you want i can send vid where you can see how this works. Same guy OSSI HARINEN my frend made my BMW M5 f10 2014 new program. (I change turbos etc. etc.) this option that i can flash bought (bmw m5 have 2 ecuboxes) ecus if i want. And yes. Bmw diagnostic ista cant able to see nothing after flashing ecus.
Re: TD1 code
What has BMW got to do with the price of fish?FinlandRS6C7 wrote: ↑Fri Nov 23, 2018 12:27 amYeah right. You must be best mecanich in your country...? If you want i can send vid where you can see how this works. Same guy OSSI HARINEN my frend made my BMW M5 f10 2014 new program. (I change turbos etc. etc.) this option that i can flash bought (bmw m5 have 2 ecuboxes) ecus if i want. And yes. Bmw diagnostic ista cant able to see nothing after flashing ecus.
How about you do what you say that you have, then you take the ECU to Audi for a TDx flag test. If your balls shrink into sesame seeds and you're never seen again, we'll know the answer. If you come back still claiming you're right, then we'll know that you're trying to sell us something... there really is no other reason for you to care so much about this topic.
- 1st Gear
Re: TD1 code
I just said. IT IS TESTED AUDI DEALER!!!!!!!!!
Re: TD1 code
Lies.
Rule 1.
He's clearly trying to sell us something, lads. He's using ALL CAPS like a dodgy used car salesman innit.
- 1st Gear
Re: TD1 code
No. Defenetly NOT SELL anything!!! And yes i know it is not leagle. But this topic is talk about CAN ecu in rs6 c7 flash that no one can read that code or anything else which audi dealer can prove or show that ecu was remapped.
We do it like this. We put tune in 2015 fl rs6 and AUDI DEALER read this car bought diagnostic vas and VCDS. This vas is used in Europe official dignostics by audi.
And there is mark that ecu is ”opened” and torque limiter is moved up.
Then we we put original tune in This obd tool. ( if you read or copy ecu files this is not leave eny mark in ecu)
Then we put this tool in this same car and this tool over write Everything which communicate in engine ecu (flash). Then we give this car again in Finland official audi dealer and they try to find something which they can prove 100% sure that this car was remapped before we overwrite ecu.
But no. Answer is no. They cant. Not vas or VCDS. And they cant. This car ecu is read earlyer in audi because service. And we didint know that they have in original tune in they computers.
Vas or VCDS didint show that car was remapped earlyer because. This ecu which we flash in this car in 100% same that they have in computers in audi. (Stock tune etc...)
I can wrote this in finnish and you can use google translater. Then i can explain this how is it works.
Tällaisen obd laitteen tekeminen ei ole vaikeaa mikä ylikirjoittaa vanhan ohjelman takaisin ecuun (ohjainlaitteeseen) muutta se miten se tulee sinne laittaa ja missä järjestyksessä se onkin sitten vaikeaa. Vain muutama henkilö Suomessa osaa ja pystyy sen tekemään vaikka olisi oikeat ohjelmistot sen tekemiseen.
- 1st Gear
Re: TD1 code
And sorry for the CAPS
- Surrey Sam
Re: TD1 code
The Dealership doesn't search for flags, they only look via ELSA for existing registered flags.
Here in the UK, Audi AG ask the dealer to run a specific diagnostic report (SVM) which gets uploaded to the Audi AG servers via VAS online. Within a minute, an automated response will be received and if a flag has been found, that flag will now be shown and registered to the database. The diagnostic tool has no capability to do this locally.
- 1st Gear
Re: TD1 code
Surrey Sam wrote: ↑Sat Nov 24, 2018 6:06 pmThe Dealership doesn't search for flags, they only look via ELSA for existing registered flags.
I dont want fight with that. I know how this is goes. But we tested this in officeal audi dealer and they use just this VAS with online. When car is remapped and tune taken off this what you said is flaged. But whit in this software in this obd tool Take tune off. Audi online VAS didint find anything whit this tune. It is exactly original. Belive or not. Its not my headache.
- 1st Gear
Re: TD1 code
I just said that i dont sell nothing. But If? Then you car is must be stock. This tool have to made every cars own data. If you get out every data in your car the answer is yes i can sell. My frend can made this tool. Then you can remapped your car. And if you some day want to take off this tune you have to send data your car when it is mapped.
Then we can made this software in this tool.
Re: TD1 code
So if I want to use this tool I have to buy it... so you are SELLING something.FinlandRS6C7 wrote: ↑Mon Nov 26, 2018 4:05 pmI just said that i dont sell nothing. But If? Then you car is must be stock. This tool have to made every cars own data. If you get out every data in your car the answer is yes i can sell. My frend can made this tool. Then you can remapped your car. And if you some day want to take off this tune you have to send data your car when it is mapped.
Bit of a pointless tool. You'd need to use it everytime the car went into a Stealer, then put your remap back on after the car comes back.
Re: TD1 code
Or
What you could do is
If you tune your car have the balls to take it in the chin when it goes bang.....instead of trying to con the dealer etc etc
Just saying like.
Just saying like.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
- 1st Gear
Re: TD1 code
bam_bam wrote: ↑Mon Nov 26, 2018 4:17 pmSo if I want to use this tool I have to buy it... so you are SELLING something.FinlandRS6C7 wrote: ↑Mon Nov 26, 2018 4:05 pmI just said that i dont sell nothing. But If? Then you car is must be stock. This tool have to made every cars own data. If you get out every data in your car the answer is yes i can sell. My frend can made this tool. Then you can remapped your car. And if you some day want to take off this tune you have to send data your car when it is mapped.
Users browsing this forum: No registered users and 19 guests
