Revolution air intake
Evening all has anyone a guide on fitting one off these ie do you leave the bottom half off the original air box as I am doing a caf as well your help would be greatly appreciated
Re: Revolution air intake
No get rid of the oem air box. Run a 102mm cold air feed straight up into the air filter.
As Mike says - fit a large CAF from behind the fog light grill (assuming you have aux radiator delete?)
My RS came with the Revolution intake and a small diameter CAF fitted so I upgraded to a larger one. I'll post some pics later but its pretty straight forward.
Yeah the normal cold air feed fitted is about 89mm as that is a good match to the air box inlet but with the revolution air intake you have a much larger opening and more potential for heat soak so go as big as you can fit. I swapped my MRC fitted 89mm for a 102mm. You might be able to get next size up but I think 102mm was fairly tight.
Heres a few random pics of my upgrade install -
Looks like a smart job. And I bet it sounds proper Nascar ?
Thanks guys for the reply’s yes have a 102 mm one was thinking off trying to make a heat shield to stop the heat from the manifold think I remember someone done it was wondering was it successfull ?
Is this what you're referring to? viewtopic.php?t=91761
Ive just used a ram-air pipe, its 100mm but is pvc instead of the usual neoprene and keeps its shape very well, its about £25 delivered with 2 alloy end pieces and 1m of ducting and i used exactly half, on a standard airbox.
Users browsing this forum: Majestic-12 [Bot] and 135 guests
