Having them rolled back in on Sunday. Hopefully they go back ok.MikeFish wrote:Ouch. This was a constant fear of mine with my 40mm springs on the 6.
B16 coilovers.FrazerD wrote:Here’s hoping it rolls back okay. Are you coilovers or springs?
That’s not so handy. I’m assume you are just going to raise it up a bit.
No I’m hoping once rolling the arches I won’t need toFrazerD wrote:That’s not so handy. I’m assume you are just going to raise it up a bit.
AgreedRobnic wrote:Ouch, think they'll be ok at that height though after you have them rolled back, typical after the new wings eh! Let us know how it goes.
Thanks for putting "rant over" at the end of your post. As I started reading it, I was thinking to myself "in the absence of any apparent full stops, how on earth will I know when this diatribe is at an end?". Luckily, you put something in there other than a full stop or an exclamation mark, so we all knew that you'd finished.
That’s my thoughts, get them rolled, if need be I’ll get PDR. All else fails I’ll buy a new wing.TrevoRS4 wrote:This same thing happened to mine with the same coilovers set a little higher than yours. I’m also on OE wheels and no spacers. Hopefully rolling it back works for you. Mine started to make some pucker markers on the fender from the pressure put on the bent part. May need to bring it to a PDR guy now.
