Cam chain tensioners/pads removal and replacement guide
Classik
Re: Cam chain tensioners/pads removal and replacement guide
Post by Classik » Fri Nov 09, 2018 11:07 am
Update : new measurements this morning. Short term phasing is between - 0.5 and +0.5 at idle on both bankd, and hoovers around - 20 under load. Both banks are tightly correlated meaning the difference between the 2 banks is always less than 2 degrees at most.
Long term phasing (group measurement 93) is even worse now: - 2°kw on bank 1, - 6°kw on bank 2 🤔
Could the position sensors be blamed for this?
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Post by Shoppinit » Fri Nov 09, 2018 12:15 pm
Déphaseur bloqué, innit.
Classik
Post by Classik » Fri Nov 09, 2018 12:32 pm
Much more clear now! 😉
The mechanical parts of the tensioner have been checked, meaning it can move and the spring has been compared ok against the other tensioner.
Post by bam_bam » Fri Nov 09, 2018 1:29 pm
Shoppinit wrote:
Fri Nov 09, 2018 10:22 am
...Might be a seized dephaser.
Sage.
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 09, 2018 1:57 pm
Or hallucinogenic drugs
Post by Shoppinit » Fri Nov 09, 2018 2:00 pm
Nutmeg. If taken in sufficient quantities it’s a hallucinogen.
Sage not so much.
Post by bam_bam » Fri Nov 09, 2018 2:02 pm
Yep, I took a whole bunch of it in prison, I've never been the same.
Post by Shoppinit » Fri Nov 09, 2018 2:04 pm
Suppository stylee?
Mr Footlong
Post by Mr Footlong » Fri Nov 09, 2018 4:00 pm
Suppository stylee?
As if there is any other way?
Current:
Gone:
Post by Shoppinit » Wed Nov 14, 2018 12:21 pm
So there is another option for these dephasers. There is a US company that makes replacements for about £300 each. I think I'd be happier with these replacement units than with a random ebay vendor.
https://www.summitracing.com/int/parts/ ... /overview/
Rockauto has one of them but not the other. Maybe they can get it for you. Never used Summit but believe they do pre-paid duty and shipping like Rockauto do.
Post by Shoppinit » Tue Nov 27, 2018 5:22 pm
You made any progress on this?
Classik
Post by Classik » Tue Nov 27, 2018 6:26 pm
Thanks for the follow up ! Actually not much progress on this front as such, but 1/I can confirm the short term phasing is at 0°at engine idle, and that both banks measure in a hankerchief under load which, to my my understanding, means the cam tensionners do their job properly (am I correct?) and 2/for the long term measurements my mechanics suspects he may have fasten one of those tensioning rolley a bit too much. Hall sensors could also be checked, I had to change them on my previous car (Atmos S6 C5) after strange phase readings. This will be checked again when I'll visit him again to mount my new wheels! ;)
Meanwhile am I wrong to assume I'm safe? A friend sent me this extract from Elsa stating I'm still within specs (-6...+6), admittedely by a very close margin.
Post by Shoppinit » Tue Nov 27, 2018 7:45 pm
You're right on the acceptable limit. You're safe, but haven't got optimal timing. Maybe some small power loss?
Classik
Post by Classik » Tue Nov 27, 2018 7:55 pm
This will be fixed foe sure, thanks for the advice, nevertheless it's good to know I won't break anything till then!
Mɐʇʇ
Post by Mɐʇʇ » Tue Nov 19, 2019 9:37 am
Just a quick addendum to Nobby's original post where he references the availability of aftermarket tensioners. Reviews/feedback on the aftermarket ones seems to be few and far between - however the 2 reviews I've found on ebay ones say avoid. So if you can't just replace the pads and need the full tensioner, go OEM would be my current view.
