Probably already a long line of people already waiting but I’m after a carbon induction kit if anyone has one. Reddies waiting!!!
WANTED!!! INDUCTION KIT!!
Re: WANTED!!! INDUCTION KIT!!
But why? Really isn’t much in terms of performance gains and if anything they’re rubbish and burn out MAFS. There is serious heat coming off them. You are honestly better off with a BMC high flow filter combined with a cold air feed.
If it’s just for looks okay I get it.
+1 and if you are prepared to modify the airbox a little a 100mm duct can be used.RS4LAD wrote: ↑Sun Oct 28, 2018 8:55 pmBut why? Really isn’t much in terms of performance gains and if anything they’re rubbish and burn out MAFS. There is serious heat coming off them. You are honestly better off with a BMC high flow filter combined with a cold air feed.
You will get a a proper Nascar sound. But heat soak will drop your BHP. It's been done to death on here. Doug bought my Gruppe-M induction kit and tried to negate the heat soak and couldn't.
Only after looks and sound, not bothered by loosing a few ponies, I drive it on congested public roads not race tracks.
I changed the 89mm MRC cold air feed to a 102mm one with my Revolution air intake and made a huge difference to the heat soak.
Im just on with adding a 100mm pipe, lots of scraped knuckles
