Vibration
LeeRS6
Vibration
Post by LeeRS6 » Wed Oct 31, 2018 2:18 pm
Having replaced my wheels with Vossens thinking that was the cause of a vibration, I can still feel a very slight vibration at slow and faster speeds, it doesn't get any worse when braking.
Anyone had anything else other than bent alloys and warped disc's?
Re: Vibration
Post by MikeFish » Wed Oct 31, 2018 7:21 pm
Did you make sure the hubs and the face of the wheels were clean before fitting the wheels? Are you using any spacers? And photos of the car with the wheels please.
LeeRS6
Re: Vibration
Post by LeeRS6 » Thu Nov 01, 2018 10:01 am
Yes running spacers and I cleaned the hubs with a wire brush and wire wool, I'm thinking I should pull the wheels off again and double check for any residue if it's not that I'm stuck with what to do next.
Not the best photo, not had time to get any good ones.
morski
Re: Vibration
Post by morski » Thu Nov 01, 2018 10:57 am
Only other thing that is rotating is the driveshafts if the vibration is felt at the front. Then there's the prop shaft as well. I've heard of some one else with vibration issues and turned out to be the drive shaft on the front. The centre mount on the prop shaft which is rubber is a bit pathetic and can fail.
Markp
Re: Vibration
Post by Markp » Thu Nov 01, 2018 2:16 pm
Test with spacers off would be my next step - just to eliminate them.
nuwanda
Re: Vibration
Post by nuwanda » Wed Nov 07, 2018 4:51 am
Vibration from steering wheel? A long shot but engine mount issue maybe?
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
Users browsing this forum: No registered users and 88 guests
