The dealer told me at my service last week that it will probably be due on my next service so they will change it.Tadass910 wrote: ↑Sat Sep 29, 2018 3:54 pmDo audi dealer change it or you need to ask for it?MikeFish wrote: ↑Thu Sep 27, 2018 12:10 amThe C7 diff oils should be changed at 40k according to Audi.innercry666 wrote: ↑Tue Sep 25, 2018 9:04 pm
Diff oils is normally 19K miles. At least it was on the RS4. I think it's the same for the 6.
Gearbox oil...
Re: Gearbox oil...
Re: Gearbox oil...
Gearbox oil...
So Audi do say the ZF is lifetime sealed and won’t/ can’t change it, you can’t even get the parts from TPS.
However if you contact ZF directly about the ZF 8HP55 box which ours has they recommend changing the oil every 60k miles.
Sourced a genuine ZF service kit on eBay for £65 which includes new gasket and pan plus all instructions on how to perform the service then extra for the oil and labour cost so all in about £400
Diff oil change is 40k miles.
Re: Gearbox oil...
If Audi won’t change it that means you no need to change it) no need invent an bicycle twice)gsc wrote: ↑Sat Oct 13, 2018 9:22 pmSo Audi do say the ZF is lifetime sealed and won’t/ can’t change it, you can’t even get the parts from TPS.
Gearbox oil...
So nevermind what the manufacturer of the gearbox say, if Audi say so then it’s right? So naive
If you’d seen the colour of the oils and the state of the filter including the amount of sludge in it you wouldn’t talk such tripe.
They also say gen 5&6 Haldex units don’t need servicing or a change of filter for the lifetime or that chain driven V8’s need the chains replaced ever, believe that too.
Re: Gearbox oil...
When I enquired about this whole sealed for life position with ZF, they told me that Audi don’t really expect to see a car back in a dealership after 3yrs/60k miles. That’s sealed for life for them as the car will be out of warranty and will probably go into the independent service arena. If the GB pops in that time or thereafter they will just pick the bill up - just as long as the car has warranty in place.
My car is at 81k now and I’ve just taken out extended warranty. I was considering a service but decided against it and will just rely on the warranty to cover any issues. But the oil in the GB must be in a bad way......
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: Gearbox oil...
diff oils Changed every 61000 km not a transmission oil, that’s what Audi says
Re: Gearbox oil...
Re: Gearbox oil...
Mine had both diff oils changed in June by Audi, so they aren't sealed for life. Think the previous owner asked for it.
Re: Gearbox oil...
Diff oils are every 40k it’s the gearbox which is a sealed for life unitab54666 wrote:Mine had both diff oils changed in June by Audi, so they aren't sealed for life. Think the previous owner asked for it.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: Gearbox oil...
So diffs oil is changeable only gearbox sealed?
- 1st Gear
Re: Gearbox oil...
Re: Gearbox oil...
Transmission oil sealed and changed, only diff oil is changeable, that was stated by Audi
Re: Gearbox oil...
FinlandRS6C7 wrote:You have totaly different service manual than ours. We have diffs and gearbox every 60000km.
Which only adds to the hilarity of Audi’s ‘recommended’ schedule, it’s not even consistent across countries
Re: Gearbox oil...
Audi said this with the C5, they're full of <beep>! Gearbox oil WILL need to be replaced to lengthen the life of the box. All oil needs replacing at some point.
Users browsing this forum: Google Adsense [Bot] and 42 guests
