Oil in coolant bottle
Here we go again, just spent a fortune getting the car motd, went to check coolant for antifreeze and find oil in the coolant bottle, not sludge just like clots of oil, checked dipstick all ok, not overheating driving ok, what can cause this, remember a mate had similar problems with an oil cooler fault, anyone know
Re: Oil in coolant bottle
Yip, looks like there is a small primary oil cooler bolted on the side of the engine block which coolant passes through, if this is cracked internally it would cause oil to mix with coolant.
Generally with burst oil over water coolers the oil mixes with the cooling system first as oil circuit has the higher working pressure over coolant. You could drain the cooling system and see what comes out, then decide whether to re-fill and keep an eye on it. I'd replace the oil cooler asap you don't want the coolant to go the other way and mix with the oil
, I found a part no but not sure if it's correct 079 117 015P
Good lad will check that out,thinking of changing the cooling rad and pipes as well
Taking to D H Automotive
Aye they are a pain in the arse lol
Probably, I think most change the hoses and cooler because they can't slacken the seized hoses off and end up damaging the cooler connections. If & when mines leaks from hoses I'd use a Dremel with cutting disc to remove the hose connections and save the cooler. What's the point in replacing the cooler if it's only the hoses that have perished with age and started to leak
Ye true, getting them to check mine, and see what it needs. Spent a fortune on it the last couple of weeks
Do the hoses have to come from Audi
Don't think so, they'll be options to buy non-oem hoses from somewhere which will be just as good if not better. Do a bit of searching on here and you'll find what make others have fitted.
Cheers mate
JH Motorsports aftermarket hoses. They’re in America though
Good stuff. I have a clutch kit and brakes from them.
lol cheers
Are Radtec oil coolers any good
Users browsing this forum: No registered users and 326 guests
