Tyre choices
jordanbutters
Re: Tyre choices
Post by jordanbutters » Wed Oct 03, 2018 12:55 pm
I changed from 255-width PZeros to 275-width MPS4S a few months back and they've been incredible wet and dry so far.
12th
Re: Tyre choices
Post by 12th » Wed Oct 03, 2018 1:52 pm
You use wider wheels, I assume? Does the increased width catch in the arches on full lock?
marc1
Re: Tyre choices
Post by marc1 » Wed Oct 03, 2018 10:13 pm
275 / 30 / 19 fit on the B7
12th
Re: Tyre choices
Post by 12th » Thu Oct 04, 2018 8:12 am
New wheels needed too, I presume?
marc1
Re: Tyre choices
Post by marc1 » Thu Oct 04, 2018 12:22 pm
I think a few people have run them on the stock wheels, both on the B7 and C5 platforms. Technically I think you’d be better off going an extra half inch wide wheel, but don’t quote me. Lots of info on here for 275 tyres though, and mixed views on whether it’s benefical or not.
FrazerD
Re: Tyre choices
Post by FrazerD » Thu Oct 04, 2018 1:08 pm
I had a quick look at this last night and 275/30 seems a bit wide for a 9 inch rim so surely the middle ground would be a 265/35? 255/35 circumference is 81.77 inches and a 263/35 is 82.63 inches, 1.1% difference. The 275/30 circumference is -2% compared to the 255/35.
Cheers :thumbs:
12th
Re: Tyre choices
Post by 12th » Thu Oct 04, 2018 2:52 pm
interesting - so speedo accuracy would change.
jordanbutters
Re: Tyre choices
Post by jordanbutters » Fri Oct 05, 2018 9:34 pm
Stock wheels at present, I have 19x10 on the way. No scrubbing on full lock. I get a little scuff on big compressions on passenger side front which I think is the arch liner retaining clip - this simply unscrews and isn’t really needed.
super7
Re: Tyre choices
Post by super7 » Thu Oct 11, 2018 11:31 am
I've got Michelin PS4 and found them to be an outstanding all rounder. Great grip in wet and dry and a nice ride. Perhaps ill go MPSS next time....
marc1
Re: Tyre choices
Post by marc1 » Thu Oct 11, 2018 1:32 pm
PS4 or PS4S? If the former, I’d go with the latter next time as they are supppsed to be SS plus some.
KernowPete
Re: Tyre choices
Post by KernowPete » Sat Oct 13, 2018 7:05 pm
I've gone from PSS to PS4. Can't honestly notice much difference.
12th
Re: Tyre choices
Post by 12th » Mon Oct 15, 2018 10:28 am
Interesting that the thing I thought less good about the PS4S was that the ride was worse than the Goodyears. Fitters had told me that they had been careful with tyre pressures and made sure they'd gone by the book. Turned out that after a week or so when I checked the tyre pressures, they had fitted fronts to rear and vice versa. When adjusted, ride is much better....
