Coolant pipes
5.0 V10 50v biturbo - 571 bhp
Woodygo
Re: Coolant pipes
Post by Woodygo » Fri Oct 05, 2018 2:08 pm
We are up to 2 hours 40 mins so far and I am ready to start refitting now
Rs6 c6 Daytona gray (sold)
Rs6 c5 silver (sold)
Seat Cupra mk3 pocket rocket (370bhp)
Woodygo
Re: Coolant pipes
Post by Woodygo » Fri Oct 05, 2018 2:11 pm
I hope this help anyone that’s thinking of doing it them self
Woodygo
Re: Coolant pipes
Post by Woodygo » Fri Oct 05, 2018 4:13 pm
Pipes are on looking good so far
Woodygo
Re: Coolant pipes
Post by Woodygo » Fri Oct 05, 2018 9:07 pm
The picture with link pipe is the cut and join pipe the other small pipe I changed the other rubber pipe just in case of any wear under the hose only £13.00 from Audi
Right so that’s all done now refiled antifreeze and water run car up to all most temperature ran out of time as had to pack away tools so will run up to full temperature tomorrow and check for any leaks 👍
Plus what’s the best way to check for air locks is it best to run up to temperature with cap off to let any air out ?
Djprev10
Re: Coolant pipes
Post by Djprev10 » Sat Oct 06, 2018 12:29 pm
Hi there! I'm new to this forum (and only been an RS6 owner for a year!) but I've now got this problem too! My car went in the the local main dealer (Poole, Dorset) for a service and MOT and has now developed a major leak from these pipes in the offside wheel arch. Audi have quoted silly money to do the job - does anyone know of a reputable and experienced independent garage near me that would be able to do this work for a reasonable price? I'm afraid I'm not handy enough to take on a job like this!
Any help that you guys can offer would be much appreciated! Thanks, Dave
Woodygo
Re: Coolant pipes
Post by Woodygo » Sat Oct 06, 2018 5:36 pm
There not to bad to do if your cutting and joining them but if your wanting full replacement then ask jim his changed his him self he is in this chat hope this helps 👍
Jim Haseltine
Re: Coolant pipes
Post by Jim Haseltine » Sat Oct 06, 2018 5:45 pm
That's because Audi will have quoted for a complete replacement of the long pipe. The whole job is 4 hose clips, a nut and a bolt. It's the last hose clip, removing and refitting the hose at that end of the pipe that takes 25 hours work. Any competent mechanic should have no problem doing a cut and join job in a few hours.
My next challenge is going to be the oil seals but they may have to wait until next spring.
Woodygo
Re: Coolant pipes
Post by Woodygo » Sat Oct 06, 2018 7:39 pm
Hi Jim I am luck mine was done in 2016 before I had it but would of been nice if they had of done these too lol never mind Jim did you have much trouble bleeding the coolant mate
Jim Haseltine
Re: Coolant pipes
Post by Jim Haseltine » Sun Oct 07, 2018 7:48 pm
Sort of. Thought I'd got the coolant level correct then luckily my first run was short but long enough for the thermostat to open - soon as that happened I got a low coolant warning.
Topped it up once and didn't have any more problems.
c3nturi0n
Re: Coolant pipes
Post by c3nturi0n » Mon Oct 08, 2018 12:10 pm
I did the job during the summer and then did "full test" in Europe covering 1500miles... no issues at all... make sure you test it for any coolant links on the clips/hose ends do recommend to run it for good 20-30miles to see if any leaks develop etc. If not, fill it up and forget about it... enjoy your motor :).
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Woodygo
Re: Coolant pipes
Post by Woodygo » Mon Oct 08, 2018 12:52 pm
Yeah I taken it out yesterday for about 5miles plus I ran it up to temperature on my drive before I when out in it stop and got some fuel again lol then gave it a little blast I will check level today 👍
c3nturi0n
Re: Coolant pipes
Post by c3nturi0n » Mon Oct 08, 2018 4:01 pm
Great stuff... enjoy it and if you are around at this w/end's Audi International @Castle Combe, give me a shout :bigwave: .
- H&R ARBs
Woodygo
Re: Coolant pipes
Post by Woodygo » Mon Oct 08, 2018 5:53 pm
Checked level all good just got back home done about 8 miles in all good still got a bit of antifreeze smell as I did drop a bottle as I was filling it up but no doubt it will burn off over time 👍👍👍👍👍
If anyone is travelling down and are passing solihull area let me no can meet and follow down
Woodygo
Re: Coolant pipes
Post by Woodygo » Tue Oct 09, 2018 2:18 pm
Update lost a bit of coolant so had look and looks like the cut joint pipe leaking it's clip just needs tightening as I was very concerned about over tightening them but I was very nice yesterday driving it 😃😃😃😃😃
ATinOf
Re: Coolant pipes
Post by ATinOf » Fri Oct 12, 2018 7:46 pm
Do you mean the dreaded oil pump shaft seal? Good luck with that one if it is
Users browsing this forum: Google Adsense [Bot] and 20 guests
