Bexpro - Remote Tailgate closure module
Re: Bexpro - Remote Tailgate closure module
Good write up Jesus!
- Surrey Sam
Let ya hair down!
I’m not criticising your work Sam. But you should have used self amalgamation tape or shrink wrap around the soldered joints. But full marks for the staggered joints and using fabric tape for re-looming.
Current ride’s
Previous rides
Previous rides
- Surrey Sam
No problem Eddie.
I didn't really deem it a harsh enough environment to require self amalgamation tape. I also didn't cut the OEM wires (just split the sheath) so couldn't utilise shrink wrap. But valid points if someone wants to go the extra mile.
I suppose some of us like are a bit more anal.
Current ride’s
Previous rides
Previous rides
- djcliffsmiff
Nice one Sam. Gonna get mine on order
Sent from my SM-G935F using Tapatalk
- Surrey Sam
Thanks Cliff, give us a shout if you have any questions.
- SteveShepherd
Can the remote tailgate be installed as a retrofit, something I'd quite like but one of the few options I don't have
2013 RS4 Suzuka Grey
Yes but it’s around 600 quid for the kit
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
- SteveShepherd
Ouch!
Top man, going to order one of these now..Surrey Sam wrote: ↑Sun Dec 24, 2017 6:37 pmRight, got the images off my phone and created some guidelines to help anyone intrested in this.
Click on the images for full resolution:
ElsaWin instructions to remove the tailgate trim panel.
Wiring Diagram
Tailgate Switch Pinout
Tailgate Lock Pinout
Label BexPro Harness
Unravel wiring harness to expose necessary wires to splice and solder into
Solder connections - Cover your boot floor with an old rug to protect from any solder spilage otherwise it could burn through your carpet.
Connect the Black and Brown first which should power module, then connect Red to the tailgate lock wire as per diagram. Turn the ignition on and press the tailgate unlock button. The module should blink quickly as it takes the signal. Now turn the ignition off and connect up remaining wires, except the orange which should be isolated. Use good quality electrical tape to wrap solder joints.
Re-wrap wiring harness using fabric tape - Tesa manufacture some.
Re-assemble trim panel and locate BexPro module - I stuck it inside the offside rear light access hole, using a cut down double sided padded number plate Sticker.
Job done![]()
B8 RS4 in the fastest colour
Hi. Was thinking doing something like this but before ordering bexpo tailgate module thought maybe should give a try with arduino... can someone know pinout of tailgate switch? download/file.php?id=44717&mode=view as in understand there is no canbus H or L thats why it's impossible to do this with VCDS? so why 4 wires?
Interesting thought. Wouldn't have thought it is too hard. A video here about reprogramming the Bexpro module fyi
https://www.youtube.com/watch?v=6xjoMvzym1Q
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
As I’m wanting to load my car up with options I think I will be going for this mod. Relatively cheap but worth it in my opinion when other leading prestige brands do this as standard. Time to get looking at local garages to do the work for me
Users browsing this forum: No registered users and 39 guests
