Cam chain tensioners/pads removal and replacement guide
Mɐʇʇ
Re: Cam chain tensioners/pads removal and replacement guide
Post by Mɐʇʇ » Mon Sep 24, 2018 4:41 pm
I read through this thread and thought - hmm, it wasn't too bad when I did it. And then saw my comment up top where I called it a biatch of a job.
Mostly because of the arse puckeriness pulling the cams out. Oh, and the noncy colour nobby did the cam covers in. Satin Black powdercoat FTW.
bilko1
Post by bilko1 » Mon Sep 24, 2018 4:56 pm
I'm going for Black crinkle finish, not that you will see it once the airbox is on.
Mɐʇʇ
Post by Mɐʇʇ » Mon Sep 24, 2018 5:39 pm
Yeah, black crinkle would work. It's magnesium, so inevitably will have corrosion marks that the crinkle will hide well.
Nobby
Post by Nobby » Mon Sep 24, 2018 10:49 pm
:D
You’ll be pleased to know that most of the paint has now come off. Painting magnesium isn’t so easy after all. Needs to be mega clean, corrosion less and then you might have a chance of it staying put.
I might polish them next time 8)
Daytona RS6 Avant
Classik
Post by Classik » Tue Oct 02, 2018 10:50 am
Hi there,
As the engine is currently out of the car (gearbox replacement), it's the good time to change those tensionners (160,000 kms here). However, as the OP rightly said, those are awfully expensive so I'm taking the pad+chain replacement route.
Problem is, I'm having a hard time to find the right parts : on eBay, every time I use the little utility that checks the compatibility with my car (RS6 Avant C5 2003), it says it won't fit, even if the title says it will :shock: See here for instance: https://www.ebay.fr/itm/4x-Gleitschiene ... 1763900124
So would you mind sharing your sources (eBay or other) to get the right parts for our cars?
Many thanks!
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
Mɐʇʇ
Post by Mɐʇʇ » Tue Oct 02, 2018 11:12 am
IIRC, they're generic across all the V8s, so those ones you have linked to look correct
Post by Shoppinit » Tue Oct 02, 2018 11:31 am
I would be so worried buying brandless parts for such a critical application.
Classik
Post by Classik » Tue Oct 02, 2018 11:40 am
Totally agree with you, however those tensioners are crazy expensive 700€ each! I can buy the chains at Audi (80€ each?) so at least this part is covered, but for those pads there must be a solution, or?
Jayjay101
Post by Jayjay101 » Tue Oct 02, 2018 12:02 pm
Great write up nobby! To the point where I’ve printed it off so I can follow it and still get it wrong and then bug shopp to help me out!lolImage
And red cam covers(and inlet pipe) look better than black
Post by bam_bam » Tue Oct 02, 2018 1:05 pm
Yes, yes they do!
Post by Shoppinit » Wed Oct 31, 2018 12:24 pm
Did you do this job in the end?
Classik
Post by Classik » Wed Oct 31, 2018 1:27 pm
Hi Shoppinit, if the question is for me, yes the chains have been replaced (original), along with the pads, not the tensioners though, couldn't justify the 800€ expense each. Looks good so far, still need to be confirmed by the measurements.
Post by Shoppinit » Wed Oct 31, 2018 1:42 pm
Cool. What's your plan? Check the wear on the ebay runners after a few thousand miles? Did you get the ones you linked to in the end?
Classik
Post by Classik » Wed Oct 31, 2018 2:25 pm
Thank you for the continued interest and support. Ideally yes, along with the measurements (if memory serves well this is block measure 90 or 93?). And yes those pads were the ones from eBay (seller cs-part-de).
Classik
Post by Classik » Wed Oct 31, 2018 2:30 pm
BTW I like those red intake hoses above (077133264) , and I need to change mine, any suggestions?
Users browsing this forum: philS2, srichards and 72 guests
