Because it says "Sport" on the bottle.....
Bugger, I bought some at the weekend and forgot to use the code.
Currently less than £30 for 5L. Much cheapness.Mark-RS wrote: ↑Tue Sep 04, 2018 10:59 pmhttps://www.halfords.com/motoring/engin ... -30-oil-5l
This was the one, I'm fairly sure. Doesn't state 505.01 on the site, but it does say it on the back of the bottle.
Even cheaper if you have a trade cardMikeFish wrote: ↑Tue Sep 11, 2018 8:06 pmCurrently less than £30 for 5L. Much cheapness.Mark-RS wrote: ↑Tue Sep 04, 2018 10:59 pmhttps://www.halfords.com/motoring/engin ... -30-oil-5l
The 505.01 spec is the PD spec for pd engines on fixed service, the VW502 spec is a very low spec. That oil is essentially built to a spec and nothing more, the 505.01 spec for PD engine is to keep the anti wear additives up to protect the cam lobes that drive the pd pump. This doesn't mean the 505.01 spec is something special, it is just to stop pd engines running sub standard oils such as 502.00 only.
No they are not ester synthetics. The Motul 505.01 will be classed as a group III hydrocracked synthetic and depending which Castrol edge it is it will be either a group IV synthetic or group III synthetic.
It is a bit of a grey area this, semi synthetics are generally not sold as synthetics as they are a blend of mineral and synthetic, however where it gets confusing is a synthetic can be made from a group III hydrocracked mineral oil. So you can have a semi synthetic that is made up of 100% mineral base stock and you can even have a synthetic made up of 100% mineral base stock. It is very hard to tell what is what sometimes.
