Alternative alloy wheels
2.9 V6 24v TFSI - 444 bhp
Re: Alternative alloy wheels
Post by Ian_C » Fri Feb 09, 2018 7:07 pm
graeme4130 wrote:
Thu Feb 08, 2018 3:41 pm
cuttsy wrote:
Wed Feb 07, 2018 6:12 pm
RS4Owner wrote:
Wed Feb 07, 2018 4:08 pm
cost of production obviously doesn't come into it. Just look at the speed limit increase to 174mph. That costs them nothing to produce, NOTHING and they're charging about £1,500
I was also told that it only restricts in top gear so you can go past in a lower one...
Whilst I'm not sure of ratios in the B9 as it has 8 gears, my B8 won't go past around 150 in 6th as it runs out of revs and needs the last gear.
Mine doesn't have the speed restrictor removed, yet doesn't hit the soft limiter until an indicated 173mph, which is a GPS 164. In reality, although it hits the limiter there, it's not got many more MPH in it anyway. We did repeated runs at a Vmax event, and that was the same result each time
Really? The 7 speed S stronic B8 S4 changes from 6th to 7th at 299/300 kph ish. And that 3.0 engine revs lower than your 4.2? That would mean the final drive on the RS would be miles shorter?
You sure yours doesn't go from 5th to 6th at 150 mph Graeme? On a private test track obviously.... :bigblink:
Graeme4130
Post by Graeme4130 » Fri Feb 09, 2018 11:38 pm
I've just watched back the Vmax footage I got on my go-pro, and it changes up from 6th to 7th around 155, and that's near the rev limiter
Post by MikeFish » Thu May 31, 2018 7:46 am
21” S6 wheels
OZ
Dolphie
Post by Dolphie » Tue Jun 12, 2018 1:33 pm
I don't want to hijack the thread but...
I posted on the B9 S4 board but only had one reply there (thanks 535dboy). I'm thinking of selling my B7 RS4 and moving to a B9 S4. I'll need a set of winter wheels for it. Genuine wheels seem a bit steep, but something like Ispiri seems to be much more reasonable. What are the thoughts on none Audi wheels in terms of quality and any warranty issues you may run into with Audi?
Brooner
Post by Brooner » Tue Jun 12, 2018 1:54 pm
i would try Ebay.de i got my wife's winter wheels genuine Audi 20" alloys with almost new winter tyres for around £1600 considering the Audi Alloys in the UK were priced at £750 a corner it was a cheap
https://www.ebay.de/sch/i.html?_from=R4 ... s&_sacat=0
don't know the offset of your alloys but the above will show you the deals
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Brooner
Post by Brooner » Wed Jun 13, 2018 12:41 pm
im starting to like these any thoughts
i know not an RS4 but cant any pictures of these on any kind of avant
Paulm
Post by Paulm » Wed Jun 13, 2018 3:45 pm
Yeah I like them. Would look very smart on the RS4
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
Ajjclarke
Post by Ajjclarke » Mon Aug 06, 2018 3:43 pm
I paint the existing wheels black on mine and added 15mm Spacers to front and 20mm to the back (H&R). if you're more conservative you could go 10mm front and 15mm back. It makes the arches look loads better and is a super cheap modification.
One tip to mention, there is a screw holding the liner in place at about 1 o'clock as you look at the drivers side wheel (RHD) and these are real belt and braces. You don't need them, they are only on the front, and they cause rubbing against the tyre that is otherwise not apparent when you remove the clip.
Brooner
Post by Brooner » Mon Aug 06, 2018 6:02 pm
Any pictures of the offending screw
Post by MikeFish » Mon Aug 06, 2018 6:10 pm
My B7 and C7 were exactly the same. Once lowered the clips / screws had to come out. Pretty much holding the top of the wheel arch liner to the wheel arch except it manages fine without it.
AndyL
Post by AndyL » Mon Aug 06, 2018 7:48 pm
"Fender arch screw mod" is very common on lowered VAG's. Removed it on my Golf R and ran it for 25000 hard miles and never had any issues, as you say, it is belt and braces.
Could you post the part numbers for the H&R spacers you used as I am very interested in getting some myself.
PieterZ
Post by PieterZ » Tue Aug 07, 2018 6:43 pm
I have bought mine from them. They're good to go.
Prices are more than half...
Specialized in new or near new take off.
https://www.ebay.de/itm/ORIGINAL-Audi-R ... =R40&rt=nc
All black B9 RS4
Brooner
Post by Brooner » Wed Aug 08, 2018 10:37 am
Anyone running 20" 10.5 25et
as this is Vossens recommendation just wanting to see if anyone has real world experience of this size on standard 275 30 tyres as regards to stone chipping clearance etc
Graeme4130
Post by Graeme4130 » Wed Aug 08, 2018 11:25 am
Normal aftermarket wheels are boring, it's the 34" Chrome ones you want to be considering :bigblink:
Eddie555
Post by Eddie555 » Wed Aug 08, 2018 11:42 am
Normal aftermarket wheels are boring, it's the 34" Chrome ones you want to be considering :bigblink: chrome.jpg
:shock:
Current ride’s
Previous rides
Users browsing this forum: No registered users and 10 guests
