Exhaust valves
TrysullRS
Exhaust valves
Post by TrysullRS » Sun Apr 22, 2018 2:09 pm
Hi
Is it possible to disconnect the exhaust valves/flaps so that they are always open?
I had an XKR a couple of years back and it was simply a case of pulling fuse 11.
Any help appreciated!
Tim
RS6 C7 PE - current
BMW i8 - current
M6 coupe 2015 comp pack - previous
Porsche 997 Turbo - previous
Jag XKR - previous
RS6 C5 - previous
Re: Exhaust valves
Post by MikeFish » Sun Apr 22, 2018 3:17 pm
Yes. First thing I did. They will cause an error but it won't show up on the dash, you'll only see it if you plug a laptop in or use an ODB app. I bought some milltek valve delete modules that plug into the wires and trick the car into thinking the valves are still connected and working to eliminate the fault. Cost about £45 for the pair.
TrysullRS
Re: Exhaust valves
Post by TrysullRS » Sun Apr 22, 2018 4:00 pm
Thanks Mike.
Do you need to protect the socket side of the connection once disconnected?
RS6 C7 PE - current
BMW i8 - current
Jag XKR - previous
RS6 C5 - previous
RS6chris!
Re: Exhaust valves
Post by RS6chris! » Sun Apr 22, 2018 4:25 pm
I believe the delete modules do that for you.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
JimbobSquarePants
Re: Exhaust valves
Post by JimbobSquarePants » Sun Apr 22, 2018 9:05 pm
Which fuse do you need to pull? And do you have to do that with them open? Or is it not that simple?
RS6 2015 - Black and Carbon
XC90 2017 - Blue - Hybrid family fun
E92 M3 - Frozen Silver - sold
VW T5 Combi - Grey - sold
E46 M3 CS - Blue - stolen
RS4 B7 - Black - sold
E46 M3 - Black with red leather - written off
Imprezza turbo wagon - Prodrive - Blue - sold
TVR Tuscan S - Green - sold
BMW 330Ci sport - Silver - sold
Re: Exhaust valves
Post by MikeFish » Sun Apr 22, 2018 11:37 pm
No fuse, just unplug them.
Re: Exhaust valves
Post by MikeFish » Sun Apr 22, 2018 11:39 pm
Thanks Mike.
Up to you.
The car side of wire and plug will be protected by the modules if you buy them as Chris said. The socket on the exhaust is up to you. I didn't bother.
Kennyg1979
Re: Exhaust valves
Post by Kennyg1979 » Sun Jul 15, 2018 12:19 am
Hi Mike
Where can you buy the delete modules for exhaust flaps?
bn8959
Re: Exhaust valves
Post by bn8959 » Sun Jul 15, 2018 8:20 am
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
MountainMutant
Re: Exhaust valves
Post by MountainMutant » Sun Jul 15, 2018 8:38 am
Does this make the car noisy from 1000rpm rather than when you put your foot down?
...and silly question, do the miltek valves work with the standard exhaust?
2017 RS6 PE Nogaro 💙
bn8959
Re: Exhaust valves
Post by bn8959 » Sun Jul 15, 2018 9:26 am
These are just simple caps for plug that connect to the exhaust valves. They simply protect the connector and also prevent a valve error being logged (as the ecu can detect the valves being disconnected).
It will just mean your valves are permanently open - making it the simplest ‘more noise’ mod.
If you replaced the exhaust with, say, a Milltek one :D then that would include its own valves. Normally you would connect them up just like the originals and they would behave in the same way.
If you want more control there is a ‘Valve Control Module’ made by Cete (and sold in the UK by Milltek). Which connects in between the normal valve connectors and the valves, allowing you to override the behaviour (including permanently open in Dynamic mode, and permanently closed in Comfor mode).
I have both a Milltek exhaust and the valve control module :)
Previous:
MountainMutant
Re: Exhaust valves
Post by MountainMutant » Sun Jul 15, 2018 9:52 am
Thanks for explaining! New C7 owner here!
I don't want to change the exhaust for now as in warranty but some more noise would be nice
Kennyg1979
Re: Exhaust valves
Post by Kennyg1979 » Sun Jul 15, 2018 11:51 pm
Thanks will give them a try.
MountainMutant
Re: Exhaust valves
Post by MountainMutant » Mon Jul 16, 2018 5:00 pm
Tried unplugging the valves today. (Waiting for the Milltek delete to turn up)
Is there a technique!! Seem stuck in and couldn't feel a clip whilst rolling around on the floor!
MM
dasquade
Re: Exhaust valves
Post by dasquade » Mon Jul 16, 2018 9:34 pm
There is (like most plugs) first a lip you need to pull out, then press... If notmistaken the lip is on the topside (could be wrong and it on the underside). Happy close space area, like always :p.
Users browsing this forum: Baidu [Spider], Google Adsense [Bot] and 41 guests
