RS4 B9 video of 20mm Spacers fitted
Gio G
Re: RS4 B9 video of 20mm Spacers fitted
Post by Gio G » Fri Jul 06, 2018 12:34 pm
Manged to get 15mm on front and rear fitted on my RS5 last week. Just looks so much better... how they should have come out of the factory..
G
Brooner
Post by Brooner » Fri Jul 06, 2018 12:38 pm
Need some before and after pics
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Gio G
Post by Gio G » Fri Jul 06, 2018 12:57 pm
Did not take a picture at the same angle unfortunately.. Top is with 15mm, feels out arches..
Terminator_X
Post by Terminator_X » Fri Jul 06, 2018 1:45 pm
Gio G wrote:Manged to get 15mm on front and rear fitted on my RS5 last week. Just looks so much better... how they should have come out of the factory..
G
Where did you buy them from pls?
TX.
Gio G
Post by Gio G » Fri Jul 06, 2018 3:10 pm
R-tec Auto design in St Albans. They used Bimecc spacers and new bolts, quite reasonable.
G
AJ13
Post by AJ13 » Fri Oct 12, 2018 10:46 pm
I’ve now been running 15mm front and 20mm back for months on it. 20mm was too wide on the front.
I had to remove one clip and screw from the wheel arch but it’s only a tiny one holding in the liner on the arch, and there’s tons extra. If you own anRS4 B9 10mm front and 15 back to be safe, and 15mm front and 20mm back are the biggest. Oh, and I got my spacers and bolts from venom motorsports. Top guys.
Brooner
Post by Brooner » Sat Oct 13, 2018 9:11 am
Thanks for the update on this
For those with the standard 20" this will save others the trial and error process
AJ13
Post by AJ13 » Sat Oct 13, 2018 9:36 am
Totally. Remember, 20mm spacers volt into the hub, so you use existing bolts, 15mm spacers you have to use long bolts that go through the wheel and spacer into the hub, so you need approx 15mm longer bolts. You may also want to buy 2 new longer locking wheel nuts, as your old ones on the front won’t work. And don’t forget to removed the horrible screw and clip in the front wheel arches.... it’s only design purpose can be to rub against tyres!
Ash_RS
Post by Ash_RS » Mon Jun 17, 2019 7:49 pm
Great video AJ13 love the set up. Does anyone have any pictures of an RS4 with 15mm on the front and 20mm on the rear? Also would this cause any rubbing or require any modifications?
quattro
Post by quattro » Sat Mar 28, 2020 9:06 pm
Tx AJ13 for the video, defintely spacers needed on this car imho.
I'm thinking of 10-15mm F/R respectivley, but i ordered my RS4 with 19'' wheels. Do you think it changes a lot? Should I go for the 20mm?
(I need 19'' for winter/road conditions here - Italy)
AJ13
Post by AJ13 » Sat Mar 28, 2020 10:11 pm
Use the 10/15 or 15/20. It won’t change much. Definitely with the 19 inch wheels you will have plenty of space with 15 front and 20 back. Stay well over there in Italy bro.
justin3477
Post by justin3477 » Thu Sep 24, 2020 9:22 am
Hey Guys
I am looking at fitting Mode spacers 18mm all round on a 2020 Facelift RS4
It has 20inch wheels
Will I have any dramas?
I have no plans on lowering the suspension
Here is a pic of my new car Image
Justin
RS4 B9 2020
Mythos Black
20" 5 Spoke EVO Wheels Gloss Black
Carbon Inlays
Black Audi Rings
Users browsing this forum: No registered users and 10 guests
